fuel injectors..........again
Old Aug 10, 2010 | 03:33 PM
jungle's Avatar
jungle
New Member
Default fuel injectors..........again
So for the 1995 318's are rated at 18.2lbs/hr....but it doesn't say at what pressure. Does anyone know?
I am told these are direct replacement, but they are listed as 26lbs/hr @43 psi. http://www.fiveomotorsport.com/product-search/?v=12676
I am toying w/ the idea of getting new injectors w/ the multi-hole nozzels....any extra pwr and mpg gained would be awesome even if it is minor. The price of the above ones is cheaper than sending mine in to Wichhunter or Marren for refurbishing.
Thanks..
Old Aug 10, 2010 | 03:57 PM
J415's Avatar
J415
https://dodgeforum.com/forum/2nd-gen...ur-trucks.html
Might answer some questions...might not.
Old Aug 12, 2010 | 11:43 AM
jungle's Avatar
jungle
New Member
actually that is the thread that started all of this!
I just wanna know if the flow rate of these injectors is the same as the oem one.....I don't want the truck to run richer. there is no reason to add more fuel to the system.
Bruce at fiveomotorsport isn't being very helpfull either:
You are getting Bosch injectors with 4-hole disc fuel nozzles. The injectors we sent are a very common upgrade for the 94-95 V-8 and are very compatible with the stock ECU.
Bruce Holt,
Sales and Tech
Fiveomotorsport.com
(562) 394-7218
----- Original Message -----
To: Bruce
Sent: Tuesday, August 10, 2010 12:29 PM
Subject: Re: dodge ram fuel injectors
Okay thanks...but the ones you sent me...are they single or multi hole?
The injectors you sent are 26 lbs/hr @43 psi...but the oems ones are said to be 18.2lbs/hr but I at what psi?
