Installing a leveling kit
Old Aug 10, 2010 | 05:35 PM
sk8erdude's Avatar
sk8erdude
Default Installing a leveling kit
hey guys, my buddy got a hell bent steel 2'' leveling kit. can i install this myself? it says i need a spring compressor, can i do it without it? anything else i need to no?
Old Aug 10, 2010 | 05:45 PM
Relex's Avatar
Relex
When I did mine I rented a spring compressor from Advanced, disconnected my sway bar and it was cake after that.
Old Aug 10, 2010 | 06:31 PM
Maxx_Magnum's Avatar
Maxx_Magnum
my buddy put a leveling kit on his 2500 without a spring compressor. I wasn't there when he did it though so I dunno what he did or how....
Old Aug 10, 2010 | 06:40 PM
If you have a jack that can lift the truck up enough to unload the springs, you don't need the compressor. Given that you already have a five inch lift though...... Gonna need a pretty serious jack.
Old Aug 10, 2010 | 09:09 PM
sk8erdude's Avatar
sk8erdude
lol no this isnt for my truck. its a friends and his is stock. so if i can get the front end of the truck up high enough the springs will have enough room to expand? will they have enough room when i put the spacer in?
HeyYou If you have a jack that can lift the truck up enough to unload the springs, you don't need the compressor. Given that you already have a five inch lift though...... Gonna need a pretty serious jack.
could i do that to my truck? it sits 2 inches lower in the front....
Old Aug 10, 2010 | 10:05 PM
lord0fsal3m's Avatar
lord0fsal3m
you can do it without a compressor, i put a 2.5" on my truck just jack it up to unload the springs and then when you put the coil in, have a buddy stand on the rotor and the other put in the spring with a pry bar. it was cake.
Old Aug 11, 2010 | 06:56 AM
olyelr's Avatar
olyelr
Nope, wont need the spring compressor but you will need to disconnect the track bar and possibly the sway bar.
You can put them on your 5" springs, but you will want longer control arms at the least, and long arms with new frame mounts would be the best. 7" of lift sucks on short arms.
Old Aug 11, 2010 | 10:06 AM
mjonesjr's Avatar
mjonesjr
Would the front need realigned after a leveling kit install since it is a solid axle?
Old Aug 11, 2010 | 10:41 AM
ferguson30's Avatar
ferguson30
I bought the harbor freight cheapies. I always make sure to double check them before use though.
http://www.harborfreight.com/macpher...-set-3980.html
