engine performance and code
Old Aug 10, 2010 | 10:18 PM
holmesd789's Avatar
holmesd789
Default engine performance and code
I have 2 problems I am looking for advisement.
My first issue is that my overall engine performance sucks lately were I am only getting roughly 8-9 mpg fuel economy and normally get 14-15. Also associated with this is the fact that I seem to have an overall performance loss, particularly going up hill where I feel like I want to get out and push to get up. Also cruising at a steady speed I will notice that my rpm's will surge up and down about 4 or 5 times, at which point I curse a few times and it gets going again.
I also have a P0455 error which is gross leak or no flow. I have inspected all the hoses and made sure they are all connected, and replaced all of the smaller 5/16" hoses. I need to try and determine which component I should look at as being faulty in that system but am not sure where to go first. I will add that I also replaced my gas cap with a new OEM cap and when I open the cap for a fill up, I don't hear the pressure release/swishing sound that would normally be made.
Since these problems have started I have replaced plugs, wires, distributor cap and rotor, air filter, pcv valve, cat and muffler. All were due anyway, at 225,00km.
Old Aug 10, 2010 | 10:27 PM
dodgeman52's Avatar
dodgeman52
check the plenum
Old Aug 11, 2010 | 12:43 PM
holmesd789's Avatar
holmesd789
I climbed up and had a look down and I don't really see any significant sign of oil, there is just a thin film of moisture inside. I have never had to add a single drop of extra oil beyond keeping it changed every 5,000 km. Would the vacuum test confirm conclusively, I see conflicting opinions in other threads?
Attached Thumbnails engine performance and code-dsc00013.jpg   engine performance and code-dsc00014.jpg
Old Aug 11, 2010 | 01:05 PM
run the vacuum test on a fully warmed engine. See what it says.
Also may want to pull the throttle body, and look around in the plenum with a dentists mirror, or similar..... there does appear to be a bit of oil in there, but, that may just be from the PCV system.
Old Aug 12, 2010 | 03:28 PM
Maverick Nos's Avatar
Maverick Nos
I replaced my exhaust on Saturday with a new Walker Direct Fit and I must have hit or pulled on the EVAP lines in the process. I started my truck this morning and had the same code P0455 and after doing a quick search on here and found the problem. I crawled under the passenger side and felt the canister. I had a hose that was slightly loose. I pushed that puppy back on and code is gone.
Old Aug 13, 2010 | 02:47 PM
holmesd789's Avatar
holmesd789
I'll recheck those hoses in case I missed one earlier. They are all on.
---I dropped the canisters below the passenger side and there was a hose clamped on with hose clamps, that connected the two canisters together. Although they did not appear damaged at first, I blew on the intake hose and sure enough the air was just pouring out around those clamps. I removed the hose and cut the ends off the hose and clamped it back down, and now I don't have any air escaping.
As for the plenum test, I had my garage do the test as per the instructions and I do not have a blown plenum gasket.
Last edited by holmesd789; Aug 19, 2010 at 02:25 PM. Reason: (found a possible problem)
Old Sep 4, 2010 | 11:51 AM
holmesd789's Avatar
holmesd789
After two weeks it appears my evap system error p0455 is solved as my cel has not generated that code. Sadly however, the light is back on and I checked code and am getting transmission code P1740. It makes sense now that this code is on why I am experiencing a surging of rpms at highway speeds of 80-90 km/hr, especially if the torque converter is not staying locked up. Could this also be causing me to come up nearly 60-80km short on a full fuel tank?
