EGR Valve on 2001 5.9
Old Aug 11, 2010 | 02:41 PM
hilliad's Avatar
hilliad
Default EGR Valve on 2001 5.9
I have heard that the 2001 ram 5.9 does not have a EGR valve. Is this true?
Old Aug 11, 2010 | 02:51 PM
Maxx_Magnum's Avatar
Maxx_Magnum
yes that is true. They changed it somewhere 95-97 I think
Old Aug 11, 2010 | 02:56 PM
hilliad's Avatar
hilliad
Thx Maxx Magnum. My CEL light is on. no codes and the gas mileage has decreased from from 12 to 10.8 and it seems to be running a little rough sometimes Have changed the plugs, wires, rotor, cap, IAC, TPS and Map sensor. Can't seem to find out the problem. Any Ideas?
Old Aug 11, 2010 | 03:09 PM
dhvaughan's Avatar
dhvaughan
did you check for codes by doing the key dance - on, off, on, off, on
if the CEL is on, it should display the codes in the odometer, ending with done.
Old Aug 11, 2010 | 03:10 PM
ferguson30's Avatar
ferguson30
Have you read the codes to see what they are? on the 01, turn the key off-on three times I believe, and it will flash the codes on the odometer. That will at least give you a direction to look at.
Old Aug 11, 2010 | 03:43 PM
hilliad's Avatar
hilliad
I have done the key dance and it says "P Done". I also took it to Advance Auto to have it checked and it showed no codes.
Old Aug 11, 2010 | 03:55 PM
dodgeram07's Avatar
dodgeram07
95 was the last year for egr on 2nd gens
maybe a O2 senor, plenum , or cat
Old Aug 11, 2010 | 04:04 PM
dhvaughan's Avatar
dhvaughan
that's wierd. i thought a CEL light and a stored code were as tightly coupled as a brother/sister husband/wife from west virginia.
reset pcm and see if some useful info comes back.
Old Aug 11, 2010 | 04:08 PM
hilliad's Avatar
hilliad
I have reset it and the cel comes back on after around 100 miles
Old Aug 12, 2010 | 03:34 AM
dakotas ram's Avatar
dakotas ram
maybe o2 sensor...but hate to just throw parts at it.
