squeak at low speed turning...
Old Aug 14, 2010 | 11:32 AM
pcfixerpro's Avatar
pcfixerpro
Originally Posted by aim4squirrels
Can somebody check and tell me if their Power steering pump pulley shaft has any front to back play? It doesn't wobble side to side, but it will pull in and out about 1/8-1/4".
I know when I put my new pump on two years ago there was no play at all.
RM_Indy's Avatar
RM_Indy
Indys pwr steering pulley moves maybe 1/16th (60k miles)
Cant say on the V10, went to pick it up Friday but bumper top wasnt right.
Bjoints & tie rods tend to go fast on our trucks.
My Indys lower bj & outer tie rods were shot with only 60k on her. (replace inners & uppers as well)
V10 just got some outer tie rods & its only got 40k on it. (dealer slid it in with damage/repairs)
Old Aug 14, 2010 | 07:17 PM
greenmachine's Avatar
greenmachine
Aim
My ride has the same issue but progressed far beyond a small chirp. I know for a fact that my ball joints are bad but that is only part of the problem. If your truck makes noise while turning the wheels at a stop or when you push down on the fender you also need to change the control(A) arm bushings. The dealers replace the whole assembly since most of the ball joints are spot welded in our trucks. This is something I know most guys do not do while at the house.
Old Aug 14, 2010 | 08:17 PM
RM_Indy's Avatar
RM_Indy
Forgot, my c arm bushings were shot in the Indy as well & swapped them while I was doing tie rods & bjs. The upper arm bushings were a bit of a PITA.
Front wheel bearings as well in both. The V10 wheel bearings started to make noise but wasnt really a squeak, kind of a groan. Did the Indys bearings cause it was all apart & dont want to go back in unless I bag it.
Old Apr 26, 2013 | 10:12 PM
Ramthis98's Avatar
Ramthis98
Just give it lots of grease
Old Apr 26, 2013 | 10:42 PM
Ramthis98's Avatar
Ramthis98
Old Apr 27, 2013 | 09:47 AM
Another two and a half year old thread? Please check dates on these before posting in them.
Old Apr 28, 2013 | 03:51 PM
Ramthis98's Avatar
Ramthis98
Lol, im just getting use to it cuz im new to the DF!!
Old Apr 28, 2013 | 03:57 PM
dhvaughan's Avatar
dhvaughan
^ hey - a semi-new forum member from Hawaii. that might be a first.
welcome to df.
Old Apr 29, 2013 | 11:25 AM
Ramthis98's Avatar
Ramthis98
welcome to df.
Thankx for the welcome
