crank sensor? my truck wont start
Old Aug 12, 2010 | 08:21 PM
andy_s273's Avatar
andy_s273
Default crank sensor? my truck wont start
me and my pops just got done swapping out 46rh tranny with a replacement cuz it was slipping... so with excitement that i had my truck fixed i went to crank it and nothin. it turns over but thats it. we had problems starting it before but i figured it was routine for the truck now. we replaced the fuel pump distributor cap and rotor and even the plugs and wires and nothing... the engine turns over slow to. so im guessings theres no spark and i keep hearing about a sensor. the crank sensor. when we finished the swap this was left dangling and didnt know what it was......
Old Aug 12, 2010 | 08:42 PM
JRob238's Avatar
JRob238
yup that looks like your crank sensor to me. IIRC it plugs in up around the bellhousing. While its loose I would stick an ohm meter to it and test it. Since you had trouble starting before.
Old Aug 12, 2010 | 08:50 PM
andy_s273's Avatar
andy_s273
is it me or did we brake it off. cuz i looked up what it looked like and tryed to reconnect it the sensor doesnt have prongs or stuff so i put it back in the hole but its like i dont think thatll work
Old Aug 12, 2010 | 08:57 PM
JRob238's Avatar
JRob238
could have but i think the prongs are at the top on the bell housing not on the sensor it self. So it would be hard for me to tell. Good news is even if it is broke it could have been the cause of your slow/hard crank so replacing it would be good anyway. Although im not sure if a local part store would carry the male end of the connector. someone else maybe able to chime in with some better info on that.
Old Aug 12, 2010 | 09:09 PM
andy_s273's Avatar
andy_s273
cuz i mean i can just slip it back into the hole... but it touches the converter wich seems retarded....
Old Aug 12, 2010 | 09:11 PM
JRob238's Avatar
JRob238
does it actually clip in or can you just slide it back out with no effort?
Old Aug 12, 2010 | 09:14 PM
andy_s273's Avatar
andy_s273
sliding it in i think that sensor part is supposed to be attached to that bracket thing like one whole peice lol but the wires run straight from the sensor no the bracket you know. im just confused
Old Aug 12, 2010 | 09:17 PM
JRob238's Avatar
JRob238
hmmm I honestly dont know. Did you try to crank it when you connected it?
andy_s273's Avatar
andy_s273
dead battery.... lol this truck gives me headaches constantly
Old Aug 12, 2010 | 09:22 PM
JRob238's Avatar
JRob238
haha i know what you mean. If it was me I would plug that sensor in and jump the battery and try to give it a crank. If it fires up at least you know a little more what your dealing with. Just my thoughts
