Shaking at 35 to 45 mph
Old Aug 16, 2010 | 07:56 PM
Many things can cause a vibration. From a bad u-joint, to an engine miss. Isolating it between the steering wheel, or the seat, will give a hint of which end of the truck to look at. A steering wheel vibration would point to something in the front. Oddly enough..... A bad U-joint in the rear driveshaft will be more of a seat of the pants vibration..... Rotating the tires, and seeing if anything changes, will let ya know if it is a tire problem.
So, the question stands. Where is the vibration felt most? Steering? Or Seat? And does a tire rotation change anything?
Old Aug 16, 2010 | 08:11 PM
trucker70's Avatar
trucker70
Default shaking
Well,it feels like the whole truck is shaking at around 35-45 miles per hr then goes away then does little surges at 55 to 60 cruising speed,not when im accelerating.Not sure what s up. Just bought this truck 2 weeks ago and dont know much about it and these problems,never had problems like these in other trucks.Thanks for any heads up,James
Old Aug 16, 2010 | 08:14 PM
What do the tires look like? I know rotating tires on a 2500 is a right pain...... LOTS of lug nuts.
Give it a shot though, see if anything changes.
Old Apr 17, 2018 | 10:38 PM
Jacob Boggess's Avatar
Jacob Boggess
Sounds exactly like what's happening to mine. What did you end up doing to fix it???
Old Apr 18, 2018 | 11:28 AM
chromed95's Avatar
chromed95
This thread is almost 8 years old, I don't think the OP has been active on here since then might be best to start your own thread of your issue.
