burnt by the exhaust manifold where it goes into the exhaust pipe. They got burnt when I was cutting off the exhaust bolt. both lines are burnt off.
use some 3/16" (i beleive) connectors and reconnect them, as theyre color coded. but to my knowledge, the only line by the manifold is the white supply line, no?
The white one comes out on the passenger side of the motor neer the intake, and as for the green one that is what I am looking for. It was located somewhere on the back of the motor. I have tried to look for the service manual to see where it hooks up but I cannot find the manual in FAQ.
The green one is still attached to the transfer case on one end, but the other end only has about 2" of line then a 90 degree rubber , and a round piece of plastic attached to it. It came off of the motor by the distributer, some where in the back, but cannot see a thing. I am still looking for the manual, but no luck.
