Flowmaster Super 44 Extreme Question
Old Aug 19, 2010 | 11:49 PM
CPTAFW163's Avatar
CPTAFW163
Originally Posted by Hick727
I know this is off topic but whats a gutted cat? Does that just mean you removed the catalytic converter?
YES and NO, it means you hollowed the GUTS out of the cat. So you can pass a visual inspection. YOu are left with just the shell.
If you do not live in an emissions state, you can cut off your cat and replace it with a straight pipe.
Old Aug 19, 2010 | 11:56 PM
01BigRedPickem-up's Avatar
01BigRedPickem-up
Gutted cat means that the internal "honeycomb" stuff has been removed creating an empty shell.If I could get away with it I would but my state has strict emission testing.Usually you can bust all the stuff out with a pipe/bar or what have you.Make sure you remove the O2 sensor and then replace afterward to prevent damage to it.On some vehicles a "gutted" cat could throw a CEL.
Old Aug 19, 2010 | 11:57 PM
01BigRedPickem-up
Beat me to it..Ha Ha!!!
Old Aug 20, 2010 | 12:07 AM
bigslick050's Avatar
bigslick050
Yes, that is what a gutted cat is. However, I should have said mine is cut out and straight piped. I'm weight exempt on emissions. (2500 HD) My bad!
Old Aug 20, 2010 | 12:31 AM
notanexit7's Avatar
notanexit7
I don't know much about muffler's as I don't have one but I seem to have noticed that with age, my exhaust has gotten a little more aggressive and throatier. The cat is the next thing to go on my truck.
Old Aug 20, 2010 | 03:58 AM
95BIGRED's Avatar
95BIGRED
no that means that there's nothing inside of the cat. cut it off and beat the hell outta the insides=gutted cat!
Attached Thumbnails Flowmaster Super 44 Extreme Question-l_6204d4361bef48d2ae86374caba20197.jpg
Old Aug 20, 2010 | 07:29 AM
heyblue46's Avatar
heyblue46
Can you get by w/o a cat in NC?? I'm down the road from you in Newport btw. I'm assuming you mean you will gut it? I figure we will eventually have exhaust analyses around here like they have to do in Raleigh and Charlotte!
Steve
Old Aug 20, 2010 | 09:25 AM
Removed, or, just blow the insides out. It is possible to remove the exhaust off the back of it, use a pipe, large bar, other sharp pointy stick, to break up the substrate inside it, then just rev the engine a couple times to blow it out.
If your area does emissions testing, your truck may not pass with a gutted cat. (though it would still pass the visual inspection, as it 'appears' to still be there.) If there isn't testing/inspection where you live, you can do whatever ya want.
Old Aug 20, 2010 | 04:56 PM
dodgeman52's Avatar
dodgeman52
i live in nc and have had no problems with my gutted cat
Old Aug 20, 2010 | 09:22 PM
notanexit7's Avatar
notanexit7
Steve
I've seen some officer's look under trucks before...not sure if they're lookin at exhaust or for drugs. I was just gonna take my old cat after I cut it off, cut it in half and take everything out then put the 2 halves back together on the new piece of pipe to make it look like it's there.
