Where do you find engines?
Old Aug 24, 2010 | 09:41 PM
  #21
CPTAFW163's Avatar
CPTAFW163
Originally Posted by DDIRI
I'm in the process of swapping a hemi into my 97. These guys who tell you that you are going to spend ten grand on it before its done are full of it, no offense to anyone but unless you have firsthand knowledge you should probably chime out, the way to do it is find a wrecked Gen3 that way you have everything I picked up my rolled 03 for a grand and after scraping the truck and selling some parts I'm about 480 into it and I still have my 360 trans and t case to unload along with some other miscellaneous parts. So the cost of a built 360 is bunk unless you consider a CAI and new plug wires built. Craigslist is the best place to find the truck you just have to be patient. There are several online with tranny and t case anywhere from 1300 to 2500. If you're going to do it do it don't let others stop you all you need to have fabricated is motor mounts PM if you have any questions I'm more than happy to help. Also the guys on the Dakota forums are a good source for hemi swaps.
I will chime out when you are complete, and it runs perfect. Make sure that you keep us updated on your progress and tally all costs.
When I was an assistant Wrestling Coach at a HS in California. THe Head coach's father had a 2ndgen ram and he wanted to put a hemi in there. He got an engine and tranny for 3000 from a collision. He had to do metalwork on the crossmember to get the engione to fit under the hood and get the tranny mounted correctly. THen he had a "NIGHTMARE" of a wiring fiasco to ensure that everything was WIRED and FUSED like the hemi. He told me that he basically merged both wiring harnesses. He had fuel problems because the hemis ran at a different PSI.
The guy I am talking about actually works at Reggie Jackson's (Former NY Yankee) shop where they restore cars for auction. Located in Seaside Ca.
It is not a simple DROP IN.
Old Aug 24, 2010 | 09:43 PM
  #22
CPTAFW163's Avatar
CPTAFW163
Originally Posted by maddog 23
Think about this...I stroked my 360, performer rpm heads, shorty headers, kb pistons, hemifever tune, and a few other little tricks for about 7K (overestimate). I make about 400 horse, and 500lbs torque. That's still less than the cost to do a HEMI swap!
Too bad you never saw this site:
http://www.precisionengine.com/rebui...nes/index.html
Dodge Ram R/T 408 Stroker with 370 horsepower and 400 ft-lbs of torque. (1992-2001 trucks) $3,999.95
Old Aug 24, 2010 | 10:25 PM
  #23
SpcD1500's Avatar
SpcD1500
http://www.bouchillonperformance.com/
