Removed my cat! Oxygen sensor question
Old Apr 20, 2013 | 02:47 PM
  #31
joekool4's Avatar
joekool4
Im having trouble after putting the jegs y-pipe in. No codes at all but it's running so rich it doesn't have almost any power. Looking for any suggestions. Thanks
Old Apr 20, 2013 | 03:05 PM
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
Did you also install new o2 sensors?
Old Apr 20, 2013 | 06:31 PM
  #33
joekool4's Avatar
joekool4
No I figured if it threw a code for the 1st one I would replace it. I talked to a coworker today who used to be a sales guy and and mechanic for ford and chevy, he said either injectors or o2 sensors start with sensors cause they're cheaper.
Old Apr 20, 2013 | 10:59 PM
  #34
What does your temp gauge say? If the ONLY change you made, was the y-pipe, did you do the non-fouler trick on the rear O2?
Old Apr 21, 2013 | 01:12 PM
  #35
joekool4's Avatar
joekool4
according to the gauges and pcm scan nothing is wrong. I bought the stuff to do the non fouler trick but it's only for the cel and there isn't one.
Old Apr 21, 2013 | 01:22 PM
  #36
zman17's Avatar
zman17
Bad o2 sensor's don't always give a CEL.
Old May 24, 2013 | 08:36 AM
  #37
Bobley's Avatar
Bobley
Am I just being stupid... I always thought there were 2 front/before cat o2 sensors (one for each bank)??
Ignore me, I have found the answer on a similar thread.
Old May 25, 2013 | 08:32 AM
  #38
Spillage's Avatar
Spillage
Both banks enter the front of a single CAT... this is where the upstream O2 is, and the downstreams O2 is in the back of the CAT or the pipe just after the CAT.
Attached Thumbnails Removed my cat! Oxygen sensor question-eastern_catalytic_20303.jpg   Removed my cat! Oxygen sensor question-642-99067hm.jpg
