Mopar M1 Intake
Old Aug 24, 2010 | 08:46 PM
  #21
Hahns5.2's Avatar
Hahns5.2
OK here we go, someone finally did a dyno of them all.
Both the M1 and AG are well bellow the Kegger in low end torque, the AG had a 5-12 ft-lb advantage over the M1 until 3800 RPMS.
Like I said, anyone who says they didn't feel a low end loss with the AG only thinks that because they were told that.
Old Aug 24, 2010 | 08:50 PM
  #22
mjonesjr's Avatar
mjonesjr
And that means I might just modify my stock intake a bit and add put in shorter bolts in the belly pan.
Old Aug 24, 2010 | 09:44 PM
  #23
Salex007's Avatar
Salex007
im all with Hahns5.2 on this the hughes is very costly and you gain same results from m1. Im sure people that get the m1 or hughes still have much modding they would like to do so those other bolts on compliment one another
Old Aug 24, 2010 | 09:50 PM
  #24
Originally Posted by Hahns5.2
Tired of hearing this too.
Dual plane was designed for CARBS, it isn't going to make a difference with multiport EFI.
Still the only person I'm aware of that has dynoed both claims they were identical.
It isn't about wet or dry flow, its about runner length/design.
If the person that did the dyno testing only swapped manifolds, I would like to know what the rest of the engine specs were, as something else was more than likely holding back.
That, and you can't expect stellar results from changing ONE part of SYSTEM.
Old Aug 24, 2010 | 10:02 PM
  #25
CPTAFW163's Avatar
CPTAFW163
this is the reason I stuck with the kegger.
Old Aug 24, 2010 | 10:03 PM
  #26
jswain's Avatar
jswain
I'd want some pretty good results for 6 bills, without having to add anything except maybe exhaust. I understand mods complimenting each other...but if I laid out 600 bucks, I'd want to feel something now. But...I'm mostly stock and totally cheap. Ha.
  #27
Raine883's Avatar
Raine883
I noticed alot of difference when i installed my airgap, but i was coming from half a plenum gasket.
Old Aug 24, 2010 | 10:06 PM
  #28
Hahns5.2's Avatar
Hahns5.2
The engine was a stock 5.9.
When I dyno my truck next month I'll do both the stock and Mopar PCM, the Mopar PCM is a huge gain in low end and I believe I have more low end than stock, the tires seem to think so too. We'll see what the dyno says. And since I have a 5 speed I can dyno at whatever RPM I want and not worry about the tranny trying to downshift on me.
Old Aug 24, 2010 | 10:13 PM
  #29
lastrights's Avatar
lastrights
ya but with sct the airgap will beat them all , i though there was another graph that showed that ?
Old Aug 24, 2010 | 10:15 PM
  #30
CPTAFW163's Avatar
CPTAFW163
How do you likie the remote trubo Hans? THere was a guy from buinicdodge that laid out a remote turbo dyno at 6-8 lbs of boost and the numbers were right in line with what I am looking for (stock engine).
Seems like a good price and "relatively" easy to tune.
http://www.bionicdodge.com/bionic/in...p?topic=9467.0
