oil presser gauge goes up and down
Old 08-25-2010 | 08:54 PM
BigRedRam95's Avatar
BigRedRam95
Originally Posted by Hahns5.2
35psi is plenty fine at idle, most engines idle closer to 20psi when warm in my experience.
The question is why it fluctuates, assuming your idle is steady.
Thats what I am wondering and as you can see in the video the rpms stay stedy.
Could it be the sending unit?
Old 08-25-2010 | 09:31 PM
matty675's Avatar
matty675
independent tests have shown the pureones to be excellent at filtering out foreign material, but a bit restrictive. also did you you use the same weight oil? correct me if im wrong but synthetics seem to be lighter than dino so that could also be the cause
Old 08-25-2010 | 09:37 PM
BigRedRam95
I used the same weight oil 10W-30. Also when I used reg oil I added a qt of lucas so that could have something to do with it also.
Quick Reply: oil presser gauge goes up and down
