probably computer or cps help??
Old Sep 3, 2010 | 08:56 PM
jKsled's Avatar
jKsled
ok heres what happened. I bought a non-mopar crank position sensor. replaced it today and voila: my bad luck is still following me. No difference.
Yes dhvaughan all i did was the tranny, I didn't touch any engine components. the truck ran for a short while (10 minutes) after I put the tranny back in.
With i had known not to unplug sensors with ignition on... hopefully that didn't ruin the pcm if it was ok before.
I will check those grounds, but if thats not it, does everything point to the PCM as being bad???? Thanks
Old Sep 6, 2010 | 07:18 PM
jKsled's Avatar
jKsled
an idea, is it possible to take my computer off, bring it to a shop or dealer and have them diagnose it to see if it's bad?
Old Sep 6, 2010 | 08:17 PM
mrfarrell's Avatar
mrfarrell
nope the majority of the dealers and shops cant diagnose the computer unless its attached to the vehicle..id recommend a junk yard computer to see if it solves your problem if your leaning towards that..
Old Sep 7, 2010 | 12:53 AM
jKsled's Avatar
jKsled
ok i won't bother taking it in then.
I am leaning towards the computer being the problem but I want to be sure that i've eliminated all posibilities before I go that route
Old Sep 16, 2010 | 04:47 PM
jKsled's Avatar
jKsled
Alright heres where I'm at. haven't had much time to work on it due to college. Now, a friend suggested that it could be the ignition pick-up in the distributor. would that give these symptoms?
obviously it would provide the no-spark condition, due to the rpm signal not reaching the computer, but would it cause interference with the computer communicating with my OBD port? I still get the error on the code reader when it can't connect.
I suppose since it's a cheaper part I'll just replace it and see what happens...
Old Sep 17, 2010 | 08:51 PM
jKsled's Avatar
jKsled
Next update:
replaced the ignition pick-up coil. This fixed the computer problem but not the no-start problem. I can now connect my code reader to the computer, but it will still crank and not start... any ideas now?
Old Sep 17, 2010 | 09:02 PM
atlrus's Avatar
atlrus
Just throwing it out there - did you check the fuses, namely the engine control fuse?
Old Sep 17, 2010 | 11:25 PM
jKsled's Avatar
jKsled
yes fuses are good
and relays
Old Sep 18, 2010 | 08:27 AM
It is possible your aftermarket CKPS is is pissing off the ECM...... Are you getting spark while cranking yet?
Old Sep 18, 2010 | 09:44 AM
jKsled's Avatar
jKsled
I didn't have time to check on the actual spark when I was home. It doesn't sound like it, the fuel pump does run and the engine cranks but does not start.
Wouldn't that throw a code though if it was? I am not getting any codes for that...
cap and rotor are basically new. not sure what else it could be
