which o2 senser is 0132
Old Aug 29, 2010 | 01:17 AM
frazzler's Avatar
frazzler
Smile which o2 senser is 0132
hello all from southwest va, just bought the 2000 1500 slt 4x4 high mileage last week. today after a long drive the check engine light came on and the truck started running rough (missing sputtering loss of power stalling at low idle hard to start back). started searching the forum and found the turn key trick to get the codes. well did this and came up with theese codes 0132/0208/0300/0302/0304.(thank you for the tip on how to do this by the way). well looked under the truck and found two of the 02 sensers which do i need to replace (money is tight till nex friday payday) I plan on replacing both but cant afford to right now and need the truck to get to work.if anyone can help I would really apreciate it,thank you in advance frazzler.
Old Aug 29, 2010 | 02:43 AM
CBR900RR19's Avatar
CBR900RR19
0132 is B1 S1 which is the Pre Cat Sensor.
0208 is Injector #8 output driver stage does not respond properly
to the control signal
0300 is Misfire detected in multiple cylinders
0302 is Misfire detected in cylinder #2.
0304 is Misfire detected in cylinder #4.
Hope this helps...
Old Aug 29, 2010 | 02:44 AM
Raine883's Avatar
Raine883
beat me too it
Old Aug 29, 2010 | 02:52 AM
CBR900RR19's Avatar
CBR900RR19
Originally Posted by Raine883
beat me too it
LOL I'm all about O2 sensors right now in the middle of changing my own rusted in pre cat....
Old Aug 29, 2010 | 07:46 AM
dhvaughan's Avatar
dhvaughan
pre-cat. do yourself a favor and unplug your old one and see if the plug is round or square. you can save a bundle by ordering a good NTK from the internet but the application guides are terrible.
the cheapest way to go is to buy the universal, and splice it into your wires, down near the sensor. i ended up doing this after i bought the wrong one. not sure of your year but mine was 4 wire. 2 white, 1 gray, 1 black. foolproof to splice in.
Old Aug 29, 2010 | 10:11 AM
Ramdude1's Avatar
Ramdude1
I have an 01 Ram 1500, what is the turn-key trick ? Or where can I find how to do it ?
Thanks !
Old Aug 29, 2010 | 10:13 AM
turn the key to on, (not start) then off, three times, in quick succession. I think codes display on the odometer?
Old Aug 29, 2010 | 10:16 AM
dhvaughan's Avatar
dhvaughan
on - off - on - off - on about 1 second apart.
this works for digital odometers beginning about ??? 98 or 99
Old Aug 29, 2010 | 10:19 AM
Ramdude1's Avatar
Ramdude1
Thank you, on my way to try !
Also, (sorry if this is a dumb question) Is there a particular sequence back to normal ? Meaning, once I am in and receive the codes, what do i do to go back to...normal mode??
Old Aug 29, 2010 | 10:40 AM
dhvaughan's Avatar
dhvaughan
you can turn the key forward to start. or backwards to off.
