a/c blower motor
Old Aug 29, 2010 | 10:13 PM
dodgehoodup's Avatar
dodgehoodup
Default a/c blower motor
Sometimes my blower motor will not come on, but if i tap on it a couple of times it will fire up and work. I took it out all the connections were good it worked perfect will i had it out and didn't act up for a couple of days. Sometimes when its on highest setting it only blows like its on 3rd setting. Ok so my question is has anyone had this problem and if so was it your blower motor or something else like the resistor or something?
Old Aug 29, 2010 | 10:20 PM
dodgehoodup
Im thinking its probably the blower motor slowly going out but hey who knows could be something else. I hate just changing parts.
Old Aug 29, 2010 | 11:06 PM
techmike's Avatar
techmike
Is there a blower motor relay on these trucks? I had a chrysler minivan with one that crapped out and exhibited the same behavior.
Old Aug 29, 2010 | 11:08 PM
dodgehoodup
I believe so. I could change that around and see if it stops it.
Old Aug 30, 2010 | 12:19 AM
mrfarrell's Avatar
mrfarrell
sounds like your blower motor is done..tapping it when it hits a flat spot is just prolonging its life alittle longer but at the risk of damaging other electrical componets by creating a higher draw to keep it operating...
Old Aug 30, 2010 | 12:31 AM
dodgehoodup
Thats what i was thinking mrfarrell. Thanks for the input.
Old Aug 30, 2010 | 07:13 AM
dhvaughan's Avatar
dhvaughan
tapping on it is probably shaking the brushes around and getting a connection. its going out, but who knows, you might get a couple more years out of it.
Old Aug 31, 2010 | 01:15 AM
99dodge318's Avatar
99dodge318
yeah mine stopped working too the other day. just tapped on the housing a bam. yours dosent blow on it highest setting? mine doesnt blow on its lowest setting.
Old Jun 1, 2011 | 09:18 PM
gitrdone17's Avatar
gitrdone17
Default Blower motor relay
Does anyone know where the blower motor relay is on 2002 Dodge pickup? Blower motor tested good. Put new resistor on. Changed control panel, still doesnt work.
