Recalibrate speedo/odo?
Old Aug 30, 2010 | 08:29 PM
dhvaughan's Avatar
dhvaughan
97 and back with speedo gear in the trans is affected by gear or tire change, since the speedo pickup is in the trans and upstream of both gear and tires.
98 and forward with speed sensor on tone ring of the diff are not affected by gear change, but it is affected by tire size.
Old Aug 31, 2010 | 05:05 PM
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by Aubrey
What do you mean the speedo is not affected by a gear change?
If you calibrate your speedo to a gear and tire package and then change the gear ratio and/or the tire size, you will need to recalibrate your speedo. It sees a different final ratio.
I mean that the way our trucks are set up, it doesn't effect our speedos, due to where the sensors are placed.
I apologize, I was being to generic by stating that all Rams don't need it. I bow to vaughan's correction. My statement only works for 1998+ Rams.
