all cylinder misfire??
Old Aug 30, 2010 | 11:27 PM
nmsadams's Avatar
nmsadams
Default all cylinder misfire??
hi im new, but i bought a 1996 ram 1500 with a 5.9. about four weeks ago. ran fine until a few days ago. check engine light came on and it ran and sounded like junk. at 55 mph in overdrive the engine is crusing right along at 1500 rpms and is shaking so bad that it causes the whole front end of the truck to hop around. this morning on the way to work i pulled over to look under the hood in the dark to see if i could see any of the plug wires arcing off eachother instead i saw the exhaust manifolds along with the brand new catalytic glowing. as i got home from work this evening i checked some of the spark plugs for their conditions. i found a majority of them to be alright but the rear plug on the passenger side was covered in oil. which no longer makes me think the cat is bad. any ideas?
Old Aug 30, 2010 | 11:54 PM
HammerZ71's Avatar
HammerZ71
Compression check time... sounds to me like head gasket or head issues...
Old Aug 31, 2010 | 12:05 AM
J415's Avatar
J415
when was the last time it had a major tune up?
Old Aug 31, 2010 | 12:16 AM
nmsadams's Avatar
nmsadams
ugh thats what i was afraid of. but why the glowing cat? and i havent had it but four weeks. havent given it a tune up yet
Old Aug 31, 2010 | 08:36 AM
ferguson30's Avatar
ferguson30
If the engine is crossfiring, you'll be burning fuel when the valves are open, and it will go out the exhaust, and heat up the exhaust hotter. Any unburnt fuel will go out to the exhaust and burn up there, or in the cat, causing more heat as well too.
Search for the spark plug wire routing TSB, sounds like that needs done too.
Old Aug 31, 2010 | 09:07 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
There is no such thing as a tune-up on these vehicles!
Old Aug 31, 2010 | 01:07 PM
J415's Avatar
J415
Am I missing something?
Old Aug 31, 2010 | 01:32 PM
greenmachine's Avatar
greenmachine
The last time I seen that happen there was a head problem. How's your fluid level? Normally if it is the cat, it will be the only thing turning red.
Old Aug 31, 2010 | 01:34 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
http://en.wikipedia.org/wiki/Engine_tuning
A tune-up usually refers to the routine servicing of the engine to meet the manufacturer's specifications. Tune-ups are needed periodically as according to the manufacturer's recommendations to ensure an automobile runs as expected. Modern vehicles now typically require only a few tune-ups over the course of an approximate 250,000-kilometre (160,000 mi) or a 10-year lifespan.
Tune-ups may include the following:
In early days, mechanics finished tuning up a performance car such as a Ferrari and would take it around a track several times to burn out any built-up carbon; this is known as an Italian tuneup.
A majority of the time most people perform what they falsely believe is a tune up they're throwing away good parts "just because". Computer controls, hydraulic lifters, tighter tolerances, and electronic ignition have all made the tune up obsolete.
Old Aug 31, 2010 | 01:51 PM
The connotations of 'tune-up' though, are replacing standard wear parts. Cap, rotor, wires, plugs, PCV valve, fuel and air filters....... Terms evolve over time..... and a lot of what used to be 'standard', is now a distant memory, and considered 'archaic'.
When was the last time you hear someone say: "I need to reset my dwell."? (unless they were talking about their garden tractor.....)
