98 ram bad front tire wear help
Old Sep 1, 2010 | 07:27 PM
jtheshowstoppper's Avatar
jtheshowstoppper
Default 98 ram bad front tire wear help
have a 98 ram thats lifted front tires are wearing out on the inside for some reason any suggestions? bent axel?wheel bearing?
Old Sep 1, 2010 | 08:03 PM
Hahns5.2's Avatar
Hahns5.2
The tires are likely toed out, get an alignment.
Old Sep 1, 2010 | 08:05 PM
Maxx_Magnum's Avatar
Maxx_Magnum
mine's doing the same thing, my front insides are wore almost completely out... I'll be able to tell you sometime soon if it was out of alignment, as I need to get tires on it and I'll have to get the alignment checked when I do...
Old Sep 1, 2010 | 08:07 PM
jtheshowstoppper
how do you do you align these? thought they couldnt cause of straight axel right?
Old Sep 1, 2010 | 08:40 PM
Maxx_Magnum
well toe in/toe out is changed by adjusting the tie rod ends
Old Sep 1, 2010 | 09:24 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You may also have a little too much negative camber as well.
Dad's truck had the same problem, but it was the locking up rearend and broke rack and pinion that was contributing to it.
Old Sep 1, 2010 | 10:50 PM
mrfarrell's Avatar
mrfarrell
ball joint's...
Old Sep 2, 2010 | 01:53 PM
SunhawkRam's Avatar
SunhawkRam
mine was doing the same thing....the guy that was going to align my tires told me and showed me that I needed to get new lower ball joints and a pitman arm :\
Old Sep 2, 2010 | 02:57 PM
JohnnyZJ's Avatar
JohnnyZJ
jack the front end up one wheel at a time and give the wheel a good shake. hads at 3 and 9 oclock and 6 and 12 oclock. there should NO movement. if there is, unit bearings are probably cooked. or ball joints. might as well replace em all if they don't look new................
if she's tight, measure your toe in/toe out. you can do it with a tape measure.
