408 Mag stroker
Old Aug 30, 2010 | 05:47 PM
matty675's Avatar
matty675
Default 408 Mag stroker
All i have to say is HOLY ****!! is this to good to be true???? will this thing bolt up just like a 360 with only an ecm flash from hemifever needed?
Old Aug 30, 2010 | 06:18 PM
GeorgiaDodge's Avatar
GeorgiaDodge
it will bolt up. just need transmission done and new gearing, your looking at around 8-10 grand depending on how far you go with it
Old Aug 30, 2010 | 06:26 PM
CPTAFW163's Avatar
CPTAFW163
A 408 is just a 360 block with a different crankshaft, rods and pistons.
yeah. you need a beefier tranny. 2400 for a tranny capable of not exploding. THen about 5000 for the engine, PCM (computer), bigger injectors, better intake.
a 408 engine outright will cost about 6 grand. about 4 grand if you get the parts and do the work yourself. But, there are LOTS of things that a beginner cannot do. Go to the hughes website and look at their instructions for a 408 stroker kit.
They also have a 426 stroker kit (hughes engines).
Old Aug 31, 2010 | 02:54 PM
matty675's Avatar
matty675
oops i forgot to post the link which was the point of my post- http://www.blueprintengines.com/popu...specs&pc_id=55
if i was to drive it like an old granma till i had enough money to buy a tranny would my current recently rebuilt tranny last? what about a manual conversion would it be cheap/easy? would the t-case hold up? how about the axles?
Old Aug 31, 2010 | 05:06 PM
CPTAFW163's Avatar
CPTAFW163
I doubt you will be driving it like grandma with a 408 in there. But since that motor only pumps out a meager 370 HP at the crank (about 280 at the wheels) your tranny should last a bit. However, you can get that same HP with the 360 and some heads/cam. Much more with a supercharger and 6lbs of boost (for about 1500 less).
There are no cheap manual conversions. YOu would need to get a new radiator, and route a clutch pedal, slave cylinder....$$$$$$$$
If funds are limited...don't go 408. THey break things.
Old Aug 31, 2010 | 06:58 PM
aim4squirrels's Avatar
aim4squirrels
Looks like a solid deal. The heads will hold it back a bit, but still pretty good. If you're itching to buy, save those pennies for a transmission. With that much power, you WILL get the urge to step on it, and then you WILL see parts of the transmission dribble out the back end of the truck, LOL
Old Aug 31, 2010 | 08:19 PM
RM_Indy's Avatar
RM_Indy
Its the 325trq at the wheels is what will spit out the trans parts.
Added a deep pan & cooler may hang in for a while
Old Aug 31, 2010 | 09:03 PM
Needs a manifold to go with that. That engine is flat tappet,and set up for being carbed. (no injector bosses on intake manifold.) So, you would have to figure that in there as well, not sure how it would like the kegger..... given the 1.92 valves, might not mind it over much. But, I question if it would even bolt on.....
But yeah, I sure it would snort torque converters on a daily basis. Ours sucked from the factory, but that in there, and it wouldn't suck for long...... it would just die. Suppose you could replace it with something better while the engine was out.... but, without rebuilding the transmission, and doing some things to beef it up, and make it more durable/reliable, it's money you would be spending again, when the trans choked and died behind the new power......
Old Aug 31, 2010 | 09:44 PM
CPTAFW163's Avatar
CPTAFW163
Nice catch there Hey You. Also, you can't run AC with that engine. I read on a lot of websites that it is a NO AC engine. Must not have the bolt holes in the heads for the accessory bracket.
I have seen 408 shortblocks for 2999 online. That is the best to buy because you will need the stock intake and you can put on whatever aftermarket heads you want.
Also, i thought it was torque, not HP that eats trannies?
Old Sep 1, 2010 | 12:42 AM
matty675's Avatar
matty675
yea i e-mailed the guy about an EFI roller engine with 2.02 heads. but seriously if i can truly contain my foot on the go pedal will my tranny hang in there till i can swing $2500 for PURE EVIL? you guys seem to be steering me in the direction of 360, why is that and how much hp can i get with heads and cam on a 360? i was looking at around 4500 on a 360 with heads cam tune all inclusive until i found that 408. also is this 408 an LA Block and will that work? if its the ssame block y cant i run a/c?
