will it work?
Old Sep 3, 2010 | 08:42 PM
frazzler's Avatar
frazzler
Default will it work?
I have a 2000 5.2 ltr extcab 4wheel drive/ the motor is shot what i need to know is can i upgrade from the 318 to 360 what would i need to change? anyone? i must be wording my search wrong but i cant come up with any thing.
Old Sep 3, 2010 | 09:10 PM
frazzler's Avatar
frazzler
well i must have been to specific in my search. all i can find is that most swaps are late 90,s and other than changing flex plate and torque conv. (until i find a computer) it is a direct swap and will actual start and run albeit lean till i get a new comp.?
Old Sep 3, 2010 | 10:00 PM
95RAM360's Avatar
95RAM360
yes thats what ive heard as well....not sure how different the 2000's are but ive heard there are some changes with the 2000's...IMHO i think it will work if you get the comp, TC, and flex plate....bolt patterns (im 98% sure) are the same thing from a 5.2 vs. 5.9
Old Sep 3, 2010 | 10:01 PM
frazzler's Avatar
frazzler
thanks man
Old Sep 3, 2010 | 10:10 PM
95RAM360's Avatar
95RAM360
check out http://car-part.com you can a comp for cheap...it lists pasrts and junkyards if you jsut fill out the info for your area....very handy website.
also make sure the motor is from at least a 98 up.....the 94-95 rams are different (tranny and emissions) vs. 96 and up....but ive heard of changes in the 98's as well (could be wrong) thats why i say get a motor thats from at least a 98...
Old Sep 3, 2010 | 10:40 PM
CPTAFW163's Avatar
CPTAFW163
just grab the PCM from the truck you pulled the motor from...and grab the engine wiring harness.
Then you just do a swap!
CPTAFW163's Avatar
CPTAFW163
but the much easier thing would be to buy a truck with the 5.9 in it. You would actually save money and time.
Old Sep 4, 2010 | 08:25 AM
If he could find a donor motor and PCM out of the same year truck, it would be a fairly simple swap. In all reality, not sure the year of the motor would really make that much difference, so long as it was 98 or newer.... the pcm would be more likely to be year specific as far as pinouts, and such go.
Old Sep 4, 2010 | 08:36 AM
CPTAFW163's Avatar
CPTAFW163
sometimes it is not as simple with a swap. If he had a 1995 and lower, it is a completely different PCM and wiring harness.
Also, the fuse boxes (PDC) seem to have different relay locations from year to year. And sometimes there might be one wire, from a corresponding pin in the PCM, that can be different from year to year. The best way to be sure is to get the engine, PCM, and engine wiring harness from the same year as the donor motor.
also, if you get a donor motor from a cali emissions truck, you better have 4 o2 sensors!!! The PCM is sxpecting 4 connections to those engines. having a cali truck STINKS when you are wanting to delete precats. YOu would need to buy 2 O2 sensor simulators from thefastman.
But for a 1996, it should not be that bad.
Old Sep 4, 2010 | 04:44 PM
mrfarrell's Avatar
mrfarrell
its a simple swap..all motor's 94 to 01 interchange...just less intake and possibly right exhaust manifold..just use everything from the intake up off of your motor if you get an older motor..and plug off the egr on the exhaust manifold if it has one or just use your exhaust manifold..and use the cam and crank sensor off your motor..and you'd also need to get a flexplate with the 5.9l..your best bet if to get hemifever to tune your pcm because the pcm in your truck is vin specific and won't comunicate properly with the other module's if you just pop a junkyard one in..you'll definitely throw a vin mismatch from the abs module..basicly if your well informed its just as easy to drop a 360 in there then it is to drop a 318 back in..
