Every time i brake from speeds of over 40, somewhat quickly, my check gauges lamp comes on and my oil pressure drops to 0. Usually its so fast I don't even see it, and by the time I stop and continue driving it returns to normal. Any ideas?
Mine did that when it got low on oil, before I fixed my plenum. Some other guys had an issue with the sensor in the oil pan. Go check your oil, if its good then your sensor is probably bad, or clogged.
