Engine hesitates, stumbles, pops on acceleration
Old Sep 10, 2010 | 02:05 PM
  #21
Maverick17s's Avatar
Maverick17s
I'm gonna give it a full tune up and replace the pre cat o2 tomorrow morning and let you all know how that works.
Old Sep 10, 2015 | 08:56 AM
  #22
Jnscowles's Avatar
Jnscowles
I had the same problem on my 1998 truck. It was the throttle position sensor
Old Sep 10, 2015 | 10:43 AM
  #23
Five year old thread..... to the day no less.
Old Sep 3, 2019 | 01:00 AM
  #24
robert miligi's Avatar
robert miligi
I have a 98 Dodge ram, that runs great until warmed up,then it has no acceleration,I've replaced both sensors ,I've replaced fuel pump, I've replaced water pump, and clutch fan, still kicking a 0505 code, so after inspecting harness replaced iac, cats don't seem to be clogged any insight would be greatly appreciated
Last edited by robert miligi; Sep 3, 2019 at 01:03 AM. Reason: Also have replaced distributor cap,rotor,plugs wires
Old Sep 3, 2019 | 08:45 AM
  #25
Both sensors? Which sensors?
P0505 is iac control. That just controls idle...... do you have any idle issues?
Old Sep 3, 2019 | 03:18 PM
  #26
robert miligi
I've ordered new iac, it was also kicking a 0132 which is o2 # 1 ,I have replaced both sensors, code went away still kicking the 505,iac.,because of a faulty clutch fan eng was running real hot,so I put a solid fan on as well as water pump,also just cleaned tcs,
Last edited by robert miligi; Sep 3, 2019 at 03:23 PM. Reason: Going to change tps as well, I'm not having idle issues cause iac stuck open
Old Sep 3, 2019 | 03:21 PM
  #27
robert miligi
I've ordered new iac, it was also kicking a 0132 which is o2 # 1 ,I have replaced both sensors, code went away still kicking the 505,iac.,because of a faulty clutch fan eng was running real hot,so I put a solid fan on as well as water pump,also just cleaned tcs,,but no idle issues,just when you go to drive it
Old Dec 2, 2019 | 02:22 PM
  #28
TyLerr Fuller's Avatar
TyLerr Fuller
Anyone ever get this figured out?
Old Aug 12, 2020 | 01:08 PM
  #29
2012RAMRT's Avatar
2012RAMRT
I know this is an old thread and I am a new member but thought it may help someone. Mine is a 1996 Dodge 3500, 5.9 gas. Idled fine, no misfiring but if I pushed the pedal to the floor it would misfire , pop back through throttle body and not pick up speed at all. If I let up on throttle it would go and drive normal as long as it was under half throttle. I did a complete tune up, replaced TPS, MAP, IAC, cleaned throttle body. Seemed like the more I did the worse it got. I had replaced the coil about 6 months ago but seen where someone else replaced their coil and it fixed theirs so I had nothing to lose and change mine and now it runs like new. Still surprised me but am very happy with it now. Don't assume new parts can't be bad.
Old Jan 6, 2022 | 05:17 PM
  #30
Angel11's Avatar
Angel11
Default 2003 Dodge Ram 1500 5.9l mag. 197k
So in reading all of these threads, we had the same issue. When the truck hit overdrive it hesitated. We were leaning towards the Cat. We put cat cleaner in the fuel tank and drove it for a while, We then changed the spark plugs and it seems to have fixed the issue. We have put a lot of work into this truck including a new PCM 6 months ago. Only thing that has not been changed is the block itself, gaskets and the cat. #8 plug was loose when we took it out. There has been no hesitation or stumbles. The only codes we had was P0420 (cat), p0455 evap leak large and p0442 small evap leak. Never a cylinder misfire. I hope this help someone else! Thanks y'all!
