318 under powered for Ram
Old Sep 9, 2010 | 11:21 PM
rt2241's Avatar
rt2241
Cool 318 under powered for Ram
I need some input. I have a 2000 Ram 1500.Auto trans w/318. It really has no power. If I were to change the motor what should I go with? And would I have to change the transmission? Wiring harness?
Thanks for any help! Rick
Old Sep 9, 2010 | 11:37 PM
Scottr1110's Avatar
Scottr1110
Could have the death flash on it, bad cat, in need of a tune up. These are preatty strong engines with good power.
Old Sep 9, 2010 | 11:42 PM
donizer's Avatar
donizer
what exactly is the death flash?
Old Sep 9, 2010 | 11:58 PM
Scottr1110's Avatar
Scottr1110
back in the day people complained that the enigne would ping under high loads so dodge made a flash for the pcm that retarded the timing and stopped the pinging but lost alot of power.
Old Sep 10, 2010 | 12:27 AM
rt2241's Avatar
rt2241
so what do I do about the lost power.....uses alot of gas too.....was tuned about 3 months ago.
Old Sep 10, 2010 | 12:29 AM
CappinHoff's Avatar
CappinHoff
It was mainly for the plenum leak. Instead of fixing the leak they reflashed the PCM so that your truck wouldn't blow the plenum.
Old Sep 10, 2010 | 12:41 AM
CPTAFW163's Avatar
CPTAFW163
being tuned and getting a tune up is different:
Tuned: Using a programmer to load a tune for a specific octane. Recommend using a 180* thermostat and doing the plenum fix from www.hughesengines or APS
Tune up: Replacing spark plugs, cap, rotor and sometimes spark plug wires.
Completely different. If you just got a new catalytic converter (magnaflow hi flow about $120), a SCT Tuner from hemifever ($275) and did the plenum leak kit ($135 from www.hughesengines.com ) then you will like how the power is.
Way less than a new engine install. Then you can go for headers and 1.7 roller rockers later down the road.
Old Sep 10, 2010 | 09:25 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Look for some of my posts where I have pictures of my Ram towing my trailer. That will tell you if the 318 is underpowered (which it isn't).
Old Sep 10, 2010 | 09:46 AM
95RAM360's Avatar
95RAM360
i bet his plenum is shot with teh deathflash.....every 5.2 5.9 magnum engine will have this problem...theres no way to get around it...
my dad had a 96 318 2wd, and he hauled a 32 foot camper with no problems at all....5.2 is a great and reliable motor
Old Sep 10, 2010 | 10:15 AM
lastrights's Avatar
lastrights
ya 5.2 is a awesome motor , more realible than the 360.
wake up the motor with the sct tuner, any tuner will erase the deathflash weather it be superchips or whatever
i know mine has a death flash and makes a DAY & NIGHT diffrence in power
