Old Aug 6, 2015, 11:51 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Upper door detent bushing help with pic - New Dodge Owner Here!!!
Old Sep 11, 2010 | 07:21 AM
littletunny's Avatar
littletunny
Default Upper door detent bushing help with pic - New Dodge Owner Here!!!
So I got the truck yesterday. Super stoked.
1999 Dodge Ram 1500
Passenger side door has a bushing that the "paw" rolls on to stop the door at various positions. This bushing is wore out. The drivers side has already been replaced at some point.
Where can I get this bushing and how hard is it to change out.
All the info in the internet has dealt with saggy doors and hinge replacements. My hinges are fine, just need that roller. You can see in the pic I greased it up cause it sounded terrible.
Thanks!!
Old Sep 11, 2010 | 09:14 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
The pin is missing as well. Your local parts store (O'Reilly, Autozone, etc) should have a repair kit in the HELP! section. The replacement bushing is brass and won't wear.
Old Sep 11, 2010 | 09:47 AM
littletunny
Thanks!
What do mean by the "pin" is missing?
Old Sep 11, 2010 | 10:00 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
There should be a pin from the top of the hinge all the way through.
Old Sep 11, 2010 | 10:03 AM
Maxx_Magnum's Avatar
Maxx_Magnum
my drivers door is missing that spring..... it won't hold itself open either fully or partway because of it, its a PITA
Old Sep 11, 2010 | 11:13 AM
zman17's Avatar
zman17
Retired Moderator - RIP
There is no pin missing in that pick. But I think the roller is part of the hinge and not available separately. Try spraying some penetrating oil on the roller to free it up if it's not spinning.
Dorman does not have that part, just the hinge pins. If they don't make it, odds are no one does. However, maybe the dealer has them separate.
Old Sep 12, 2010 | 08:41 PM
gipperkid's Avatar
gipperkid
Ummm, you'll have to buy a whole new hinge to fix that problem. Sorry bud.
Old Sep 12, 2010 | 09:56 PM
Sheriff420's Avatar
Sheriff420
I just put a glob of grease on mine when it starts squeaking.
If you want to replace it then hit the self help section at advance like VW said and get to pounding on that pin with a punch and a hammer.
Old Sep 12, 2010 | 10:17 PM
CPTAFW163's Avatar
CPTAFW163
I remember my mom and dad had some 1976 cadillac when I was growing up (80s) and that door was either FULLY OPEN or CLOSED. None of this half way garbage.
Old Sep 12, 2010 | 10:42 PM
And the door probably weighed more than you did......
