97 5.9l 4x4 running hot and funny oil pressure gauge
Old Sep 12, 2010 | 09:21 PM
dannieboiz's Avatar
dannieboiz
Default 97 5.9l 4x4 running hot and funny oil pressure gauge
I just bought a 1997 1500 Ram 5.9l 4x4 everything is in very good shape for its age.
I was doing a 70 miles trip home and the tempt was running at about 3/4 the entire time.
When I pulled into an exit, my oil pressure dropped to 0 and stayed there. It would go back to normal if I pop it in neutral and everytime I pop it into gear it would go back to zero. When the truck is moving it's fine though.
Was wondering if these two are related?
When I turn on the heater it was hot/warm and there were times it was very hot. I'm hoping the heat is just a thermostat issue. I checked the oil and it's not milky.
Old Sep 12, 2010 | 09:33 PM
For the oil pressure.... sounds a lot like an electrical problem. Either a short somewhere, (maybe somewhere close to the shift linkages......) or a bad sending unit.
Change the thermostat, and do a cooling system flush, including a descaler. Does your cooling system hold pressure?
Old Sep 12, 2010 | 09:45 PM
dannieboiz's Avatar
dannieboiz
how can I tell if the cooling system hold pressure?
Old Sep 12, 2010 | 09:50 PM
Run the engine warm, (temp gauge tells you its up to operating temp.) and squeeze the upper radiator hose. Should be pretty solid, and stay that way for a while after you shut the engine off. The engine will have to cool quite a bit for the pressure to go down.
Also, while it is pressurized, and you have the hood open..... look around for leaks. That is the best time to find 'em.
Old Sep 12, 2010 | 09:54 PM
dannieboiz's Avatar
dannieboiz
I will try that tomorrow morning. thanks!
BTW: I did a quick seach here and it seems quite common to have this oil pressure issue.
dhvaughan's Avatar
dhvaughan
if its holding pressure, then its acting normal and the level in the overflow tank varies very little, if any.
if its not holding pressure then its spewing a lot of coolant into the overflow tank or out some leak somewhere.
your temp should remain steady about 195 or 200. if its not doing that, you should check/maybe replace your t-stat. also consider that your radiator might be stopped up - either the air flow or the coolant flow. as a test, you can run with no t-stat. with no t-stat and good radiator temp should run about 160.
