Is my battery going?
Old Sep 12, 2010 | 09:34 PM
dodgeramit_10's Avatar
dodgeramit_10
Default Is my battery going?
Iv had problems starting my truck in wont turn over on the first turn of the key it usually took 2. When I went to leave work it chugged and took about 4 turns of the key and it went. Is my battery going or starter.
Old Sep 12, 2010 | 09:39 PM
Have 'em both tested. Most any parts store should have the right tool for the job. They can load test the battery, and run a draw test on the starter. Should tell the tale.
Old Sep 14, 2010 | 07:13 PM
InTheDirt's Avatar
InTheDirt
I've had the same problem on mine since I bought it in March. Intermittent, at best, tho. 3mo ago, the starter checked out just fine, load test on the battery was fine. Ignition switch tested fine. I replaced the starter relay, and it seems to have resolved the issue. Fast-forward to yesterday, and the problem is back. I've switched the starter relay with another in the fuse panel, and didn't have issues with it today. Don't know why its doing this...........cheap Chinese parts?
Old Sep 14, 2010 | 10:22 PM
dodgeramit_10
I charged my battery for a hr got it tested, its fine. truck ran fine last night and this morning almost didnt start tonight. Possible solonoid? or is my e-fan taking to much power out of the battery? Am I thinking to far ahead and its something simpler.
