Door panel bulge!
Old Sep 16, 2010 | 01:06 PM
Vulture's Avatar
Vulture
Default Door panel bulge!
Hey all, noob to this forum.....
I have a bit of a problem, I recently replaced all 4 stock speakers in my '97 with kickers. The issue I'm having is with the front 6x9's bulging my door ( I know, I should have joined and researched on this forum before I set out on the swap :P). Both doors bulge slightly, not too noticeable, the problem arises from a rattle in the passenger door! Could this be related to the bulge or perhaps to not having the panel on properly (broken clips, etc.)? If a bulge problem, any recommended solutions short of cutting the panel and putting speaker grills on?
Thanks!!
Old Sep 16, 2010 | 02:31 PM
Scottr1110's Avatar
Scottr1110
i put kickers in mine i had to space them out about a 1/4 inch because the magnet would hit the window channel and mine bulge as well but not to bad i dont hear a rattle on mine though.
Old Sep 16, 2010 | 03:09 PM
FFFD827's Avatar
FFFD827
I put pioneer 6x9 in my doors didnt have a problem with a bulge but i had a rattle i that was not there before. took it back apart turned out to be a half round black thing with wires connecter to it swingin around i just used zipties to hold it so something now the only rattle is from broken door panel clips.
Old Sep 16, 2010 | 03:17 PM
PurplDodge's Avatar
PurplDodge
When I first read the title, I thought that your door panels are horny. Do they rub your legs while you drive? Road Head?
Old Sep 16, 2010 | 03:36 PM
CPTAFW163's Avatar
CPTAFW163
ah, the secret to getting 6K posts in 2.5 years.
Old Sep 16, 2010 | 03:52 PM
dsertdog56's Avatar
dsertdog56
Default That's funny right thar!
My doors have the aftermarket bulge, but no rattle. I replaced all my door clips with new ones when I reinstalled the panels.
I'd love to find a set of speakers that didn't make the door panels do that.
Old Sep 16, 2010 | 04:01 PM
FFFD827's Avatar
FFFD827
I just used pioneer 6x9s i got at walmart they fit great i just used the door as a screen and did not install the ones that came with the speakers.
Old Sep 16, 2010 | 09:49 PM
dhvaughan's Avatar
dhvaughan
i used 1/4 nuts as spacers to move mine out away from the window frame. that added a little bulge to the panel, but its an ok amount.
use a door panel tool and remove your passenger side and see what the rattle is.
i would not cut holes in the door panels. i'd rather have a bulge than an ugly grill mounted on top.
Old Sep 16, 2010 | 10:17 PM
spankythedog's Avatar
spankythedog
ive got some 4 ways I put in mine and the panels bulge too lol, but no rattling. A little from the cheap side panels in the back, but thats a sub woofer issue that I dont care enough about to fix
Old Sep 18, 2010 | 10:54 AM
Vulture's Avatar
Vulture
I didn't need to space them out, however; I'll pull them off again to check and make sure I don't have any rouge wires or such dancing around. Then put new clips on. Hopefully that'll do me..........Thanks for the tips!!
