Hello all a little tech help needed
Old Sep 19, 2010 | 09:16 PM
ash_09's Avatar
ash_09
Default Hello all a little tech help needed
I have two potential problems, and I am not sure if they could be linked. Firstly I have a 01 Ram 1500 5.9l.
I seem to be going through anti freeze quickly, and I never seem to have any puddles under my truck. My windshield has a coating of greasy fog on the inside of it, I am wondering if there is anyway my antifreeze is leaking into the heating system slowly and going up through the defrosters. if thats a possiblity can a simple can of leak stop cure it?
The second thing is on ocaision the truck won't start proper. I turn the key it starts but dies immediatly afterwards. If I start it with the gas depressed a bit it will run. However the second I let it drop down to idle it dies. This has happened in all weather conditions including two weeks with out rain. Sometimes it runs, I stop and turn it off and then the problem rears its ugly head. Sometimes I go weeks with out this happening.
Any ideas?
Thanks
Ash
Old Sep 19, 2010 | 09:25 PM
dhvaughan's Avatar
dhvaughan
your heater core is leaking. the proper fix is to remove the dash and replace it. it'll cost a fortune at a shop. you might squeak by with some stop leak. and the last option temp fix is to disconnect the heater hoses at the firewall, connect them together, and bypass the heater core. obviously this will yield no heat.
poor idle is most likely the IAC. remove the old one and make sure the port is open into the throttle body. you can poke it out with a small screwdriver. if port is open ok, then replace IAC for about 40-50 bucks at any parts store.
Old Sep 19, 2010 | 09:33 PM
CBR900RR19's Avatar
CBR900RR19
Oh hell ya beat me to it LOL!!!
Old Sep 19, 2010 | 09:46 PM
dhvaughan's Avatar
dhvaughan
gotta be quick!
Old Sep 20, 2010 | 08:31 AM
ash_09's Avatar
ash_09
Thanks for the response guys, I'll have to get right on it because winters fast aproaching here in New England and with out a good running defroster I'm up the creek with out a paddle.
Old Sep 21, 2010 | 04:44 PM
ash_09's Avatar
ash_09
Well new IAC is in and I used stop leak in my radiator to try to save from having to do a big job. Now I guess its just time to play the waiting game to see if the truck has any starting problems and see if it gets low on antifreeze again.
Thanks guys
Ash
Old Sep 21, 2010 | 07:05 PM
You realize the stop leak is only a band aid fix, right? And of course, it will decide to stop working when it is well below freezing outside.... might wanna take advantage of the warm weather, while you have it, and do the 'big job' while its NICE out, instead of in the dead of winter.
Old Sep 21, 2010 | 08:15 PM
CBR900RR19's Avatar
CBR900RR19
Been there!!! So true so true LOL
Old Sep 21, 2010 | 11:03 PM
ash_09's Avatar
ash_09
yeah I do realize it...just short on time and even shorter on cash. Just hopeing to make it through this winter. thanks for the heads up though
Old Sep 21, 2010 | 11:24 PM
dhvaughan's Avatar
dhvaughan
anyone ever use black pepper or a raw egg as a stop leak ?
it actually works...
