Audible Engine Knock
Old Sep 20, 2010 | 09:02 AM
Annihilator_X9's Avatar
Annihilator_X9
Default Audible Engine Knock
Hey guys, I've got a knock happening when my truck is cold. It's quite noticeable inside and out. But once she's up to temp, it's pretty quiet. I'm wondering if it's a bearing going out because it sounds like it's coming from the bottom of the engine. I know my old Grand Am suffered from piston slap when it was cold (most GM's do), do Dodges? This is my first Dodge.
Oh yeah 1998 318 Auto.
Old Sep 20, 2010 | 10:17 AM
95RAM360's Avatar
95RAM360
Is it pinging? sounds like you need to do the plenum IMHO
Old Sep 20, 2010 | 11:30 AM
donizer's Avatar
donizer
due for an oil change soon? dads truck was in desperate need of a filter and it would starve the engine of oil momentarily after startup and would knock pretty bad, sounded like a top end/lifter knock though. Not like the bootom end knock you described
Last edited by donizer; Sep 20, 2010 at 11:31 AM. Reason: put valve, meant lifter/fat fingers
Old Sep 20, 2010 | 02:20 PM
Annihilator_X9
I'm doing my plenum this week. I'll see if that will help. I didn't think it would be though because it quits when it's warm. Or at least it's not as loud. Made me think it could be oil starvation when it's cold. I'll change the oil and replace the filter. It's probably due anyway.
Old Sep 21, 2010 | 10:49 PM
jswain's Avatar
jswain
Not a ticking noise is it? Sometimes exhaust manifolds will leak/leak worse when cold and then quiet down when the engine heats up.
