Transmission Test Port?
Old Sep 20, 2010 | 02:13 PM
Pacmanloads's Avatar
Pacmanloads
Default Transmission Test Port?
Hello everyone,
I am going to be installing a transmission temp gauge and was wondering if anyone knows if the 46RH has a test port to install the sensor in .
http://www.glowshift.com/instruction...ture-Gauge.pdf
If so where would it be located ....I am not at home currently and can not just look. Thanks in advance.
Old Sep 20, 2010 | 04:44 PM
RamSport97's Avatar
RamSport97
Follow the dipstick tube all the way down to the transmission, and you will see this servo port, that is what I used.
Old Sep 20, 2010 | 05:21 PM
CPTAFW163's Avatar
CPTAFW163
Get a Derale trany pan. It has cooling tubes built in, a drain plug, and a bung for a temp sensor. 129 at summit
http://www.summitracing.com/parts/DER-14210/
Old Sep 20, 2010 | 05:31 PM
Pacmanloads
Perfect...thank you ! Did it thread right in or did you need another fitting?
Old Sep 20, 2010 | 05:36 PM
Pacmanloads
I may end up going with a deep pan eventually , I already have a very large Aux Cooler installed , I do a lot of wheeling and I'm worried about dragging the pan or breaking off the sensor on a rock or branch. So that would mean I would also have to install a skid plate underneath. I just want to be able to monitor the effectiveness of my cooler and see if it is efficient enough before getting a deep pan . But thank you .
Old Sep 20, 2010 | 10:47 PM
RamSport97's Avatar
RamSport97
No problem, it threaded right in, although, I used an Autometer Z series, not glowshift, but I would imagine the senders would be the same if not similar. If I recall correctly, I didn't thread it in all the way, as other members had issues with the sensor interfering with an internal mechanism. Make sure to use some white Teflon thread tape to prevent any leaks.
Old Sep 21, 2010 | 12:15 AM
dodgeram07's Avatar
dodgeram07
my Autometer when it good on my 46rh in the front port
Old Sep 21, 2010 | 12:59 AM
MrRuckuss's Avatar
MrRuckuss
i had the autometer can't remember the number but something like 5680 or something like that, it was the expensive model as it changes colors at different temps, but anyways, i used the front servo on my 47re and took it out once i traded my truck and the sender was bent, my suggestion would be to drive it for a day or two then pull it out to make sure it isn't intereferring, i got a little worried when i saw part of the sending unit was missing, but again i traded the truck so it isn't my problem anymore.
Old Sep 30, 2010 | 03:52 AM
Joey Buentello's Avatar
Joey Buentello
dude I'm putting in a C2 trans temp gauge this info really lent a helping hand.
