shifting funny...
Old Sep 23, 2010 | 11:56 AM
bigblock79's Avatar
bigblock79
Question shifting funny...
so my 1997 ram has a rebuilt transmission with only around 10k on it... BUT... when im cruising and want to pass someone, no kick down... and it seems the shift points arent right... could this be the shifting solenoid or sensor or whatever?
Old Sep 23, 2010 | 12:07 PM
dodgeboy1979's Avatar
dodgeboy1979
it could be or it could be the cable hookedto your throttle body isn't set right for the shift points.
Old Sep 23, 2010 | 12:14 PM
losi8ight's Avatar
losi8ight
Mine doesnt seem to shift right either, it shifts way to early. I just manually take it out of overdrive when i'm accelerating, really wish it would work correctly by itself though.
Old Sep 23, 2010 | 12:53 PM
CappinHoff's Avatar
CappinHoff
Search the forums for tv cable adjustment. That might be your issue. Does it rev high before it shifts?
Old Sep 23, 2010 | 01:52 PM
dodgeboy1979
a tranny shop will properly set up your tv cable for you for like 25 bucks, take it to one and have them do it.
Old Sep 23, 2010 | 02:35 PM
CappinHoff's Avatar
CappinHoff
Depends on where you live. Around me I've had it estimated at $100 and higher. Just look at this guide.
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
No need to pay for something that's easy to do if you don't have to.
Old Sep 23, 2010 | 05:15 PM
bigblock79's Avatar
bigblock79
same problem i have, noticed there was way too much trans fluid and drained the extra, improved alot but not all the way...
Old Sep 23, 2010 | 05:16 PM
bigblock79's Avatar
bigblock79
sometimes it will seem to hit neutral for a second then the next gear...
Old Sep 23, 2010 | 06:35 PM
CappinHoff's Avatar
CappinHoff
That what mine does. RPM's get to about 3k.3.5k and stalls then shifts. Or if I let off the gas it'll shift. It happens more when driving in the city than interstate.
Old Sep 23, 2010 | 06:59 PM
bigblock79's Avatar
bigblock79
exactly!
