96 Dodge Ram 5.9L cat delete
Old Sep 23, 2010 | 05:15 PM
dodgetruck2's Avatar
dodgetruck2
Default 96 Dodge Ram 5.9L cat delete
I had an exhaust shop put on a new cat a couple years ago because the old one collapsed, and i have about 20000 miles on the new one, and i think it collapsed again, takin it in tomorow to get checked out, at 300-400 dollars a pop, i want to just cut it off
can i do this with o2 sensor and not mess up the fuel/air ratio
truck is a 1996 Dodge Ram 1500 5.9L 360 Magnum
Old Sep 23, 2010 | 05:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Do a search here for "plenum". It's blown and that's what is ruining the cat.
Old Sep 23, 2010 | 05:49 PM
dodgetruck2
?????????????????????????????didnt find anything
Old Sep 23, 2010 | 06:07 PM
zman17's Avatar
zman17
LOL, there are literally thousands upon thousands of threads on the plenum subject here.
Old Sep 23, 2010 | 06:09 PM
dodgetruck2
then post a link because i searched plenum and got nothing
Old Sep 23, 2010 | 06:24 PM
zman17's Avatar
zman17
Whatever dude! I just used the search feature on this site and got ten pages of threads that have at least the key word plenum.
Old Sep 23, 2010 | 06:47 PM
boaboa's Avatar
boaboa
Removing your cat will kill your backpressure in your exhaust system and f up your fuel/air ratio. I did this for a while, and while it sounds simple to do and makes your truck sound like its ready to eat a kindergarden class, it lowers your overall horsepower and burns gas. Plenums in these dodges came stock with a steel plate, which expands and contracts at a rate different than the rest of the block, ripping up your gasket and causing oil to leak into the engine and all other kinds of fun stuff. You need a plenum plate replacement kit - anyone with these trucks running remotely well has already done it. Go to hughesengines.com and order part #7720 - Plenum repair kit.
You can get a new magnaflow cat for pretty cheap as well, I don't remember paying more than 70$ for mine. Its a little bit of work to get the plenum off, but its well worth it. You may want to consider redoing your rotor, wires, and putting a lower t-stat in there too while you're at it. You won't be dissapointed.
Old Sep 23, 2010 | 07:14 PM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by boaboa
Removing your cat will ... f up your fuel/air ratio.
As respectfully as can be: No, it will not. If it's not failed, the pre-cat oxygen sensor will give an accurate signal whether there's a cat behind it or not and the PCM will regulate to achieve the correct signal at that point.
Old Sep 23, 2010 | 09:37 PM
dodgetruck2
so what kind of mechanical knowledge is required to put the replacement kit on, any special tools needed, and roughly how much time needed? i have your basic know how mechanic skills but have never been to school for it
that thermostat is a no brainer for 12 bucks, i just took it out and drove it and i wana say it runs great but ill just say it runs like normal
Old Sep 24, 2010 | 01:36 AM
Scottr1110's Avatar
Scottr1110
i hollowed mine out havent thrown a light or any thing and getting 13 mpg so u will be fine i would assume. I dont know if its a stick shift thing or not though as to why i dont throw a check engine light.
