? on installing piston onto rod
Old Sep 23, 2010 | 07:34 PM
nathangfnd's Avatar
nathangfnd
Default ? on installing piston onto rod
SO i need to install a piston onto a rod bbut the closest shop is over an hour away so was wondering if its possible to do in a normal garage.
If so how?
Old Sep 23, 2010 | 08:05 PM
dodgeram07's Avatar
dodgeram07
i have still it done in the garge all the time
http://www.youtube.com/watch?v=H2YrL3k__dA
Old Sep 23, 2010 | 08:07 PM
It is either press fit, or floating pin.... I don't know which. If it is press fit, you need to be able to, oddly enough.... press the old one out, and press the new one in. Just using a hammer and a dowel is NOT a good plan.
If it is floating pin, there will be be snap rings inside the bore that it goes thru, just pop one out, and the pin should slide out. (not necessarily easily, but, shouldn't require tools to get it out, aside from snap ring pliers....)
Is there ANY flavor of machine shop around you? Even a tool and die shop should be able to manage it for you.
