Installing 2 digital gauges: 2 questions (pics)
Old Sep 25, 2010 | 02:04 PM
CPTAFW163's Avatar
CPTAFW163
Default Installing 2 digital gauges: 2 questions (pics)
Alright,
I am finally putting in my digal gauges (tranny temp and AFR). I have a couple of questions:
1. Since I am installing TWO gauges that need switched 12V power, how can I splice TWO fused connections and still be safe?
The reason why I ask, is because i don't want to splice two gauges to the ignition wire and then have problems because of current draw from one wire.
2. I also want to splice into the Dimmer switch. For when you can control how bright the gauges are. Or maybe should I just splice into the Headlight 12V power (on/off). I was just thinking that having the aftermarket gauges' backlight (illumination) be able to dim and brighten like the dash would be a nice addition.
3. How do I use a voltmeter on these wires? I don't know where to find a good ground around a bunch of plastic.
Here are some pics:
Which one is the dash illumination dimmer?
When I am testing these to see which one is a switched 12V, where yould you ground?
Old Sep 25, 2010 | 03:20 PM
There is a service manual in the FAQ section, that has wiring diagrams (including wire colors ) for your truck. You should be able to look at the diagrams, and pick the wire you want easily, without ever having to disassemble the truck. (which you already have..... ah well.)
As for ground, use a door hinge, or something else metal for the VOM. If you are referring to grounding the gauges...... have a very close look at the wiring diagrams... dodge seems to like have circuits always powered, with switches and such providing the ground....... Make sure you don't provide a ground for a circuit, that is unswitched, hence, leaving them ON all the time......
Old Sep 25, 2010 | 07:54 PM
CPTAFW163's Avatar
CPTAFW163
the wiring diagrams do not have every wire. I tried 3 different places. Chiltons, Haynes, and the one online. Does not show what I need.
Old Sep 25, 2010 | 08:05 PM
CPTAFW163's Avatar
CPTAFW163
and also, I have no idea how to use a miltimeter and all I did was get sparks to fly off the negative stick, and got the wires nice and warm.
Any tips would help!!
Old Sep 26, 2010 | 12:02 AM
mrfarrell's Avatar
mrfarrell
the black/yellow at the headlamp switch is the positive for the park lights..and the blue wire in the ignition harness is switched 12v positive..if your worried about draw..which i wouldnt be install some relay's..couldn't tell you on which wire is the dimmer switch thou.
Old Sep 26, 2010 | 01:32 AM
CPTAFW163's Avatar
CPTAFW163
Yeah, i got the black/yellow. ANd the blue.
I am installing some fuses in line with the gauges. 3 amps for each gauge.
Thanks for helping. Now that I hear you saying something I was thinking along the same lines of...I feel much better going forward.
--Dan
Old Sep 26, 2010 | 02:22 AM
RM_Indy's Avatar
RM_Indy
Not positive if Im reading the schematics correct but think that the dimmer pwr lead is the pink with light blue tracer.
Check 01service manual
Go to page 8W-50-2 (also see it 8W-45-7)
Bottom left of the Central Timer Module C2 on left side is the Courtesy Lamp switch output
Goes to courtesy lights & cluster from there.
Old Sep 26, 2010 | 02:38 PM
CPTAFW163's Avatar
CPTAFW163
AHHHHHH, I just found it. you are correct. I figured out how to use the multimeter (thank you youtube) and I went through every wire.
NOW IS THE LAST QUESTION AND I CAN INSTALL:
For the 12V power from ignition:
1. I am going to fuse this, but can I install BOTH power leads (one from the tranny and one from the AFR gauge) to the same connection in the fuse?
It calls for a 3 amp fuse for each gauge, so does that mean I need to use 6 amp for this?
I was thinking this:
__________12V ignition_________
splice
3A 3A
Tranny temp AFR gauge
OR:
3A
Old Sep 26, 2010 | 02:41 PM
CPTAFW163's Avatar
CPTAFW163
OK it did not come out like I spaced it but you can catch my drift. It is either a bare splice that splits to 2 3A fuses (one for each gauge). OR splicing a 3A fuse and then splicing the AFR and tranny temp gauges to the 3A fuse.
OR, for the second one would I need a 3 Amp fuse.
I don't know if you add the amps together or not.
Old Sep 26, 2010 | 06:35 PM
CPTAFW163's Avatar
CPTAFW163
OK,
Everything is wired. The tranny temp gauge works great. The AFR gauge needs some more work (shop to weld the bung on for the O2 sensor).
Everything seems fine. I used some beefier splicers and that worked well. They are the "all weather" ones from autozone. They came covered in dielectric grease and the plastic was harder.
Well, this was not as hard as I thought. it was just a lot of work to prepare for (since I never did this before except for an analog water temp sensor).
I will take some pics later tonight. I have to eat dinner.
--Dan
