Help with fan!!!
Old May 31, 2005 | 11:21 PM
mo1972's Avatar
mo1972
Default Help with fan!!!
Dodge Ram 1500 5.9 V-8 '00
I am changing the water pump; but I can't get the fan off. I am trying to loosen the bolt between the fan and the water pump pulley but it just spins. Yes I have the drive belt on. Is there another way to get the fan off or is there a way I can stop that pulley!
Old Jun 1, 2005 | 01:04 AM
MAGICDSSMAN's Avatar
MAGICDSSMAN
Default RE: Help with fan!!!
When I changed my water pump a few months ago I cut a 2x4 and placed at the base of one of the fan blades. It worked well for me so if you don't come up with something else give that a try .
Old Jun 1, 2005 | 01:34 AM
steve05ram360's Avatar
steve05ram360
yes, go get a strap wrench at sears, should be under $20 bux and wrap it around the water pump pulley... that's how I did mine...
[IMG]local://upfiles/1508/CA301688B72A4370B4CBE3B6828E990A.jpg[/IMG]
