Steering Issue????????
Old Sep 29, 2010 | 10:43 PM
lennyb3us's Avatar
lennyb3us
It's a 2wd 5.9. I checked the steering shaft and found alittle play not very much at all. Could it be binding inside the box itself???????????
Old Sep 29, 2010 | 10:56 PM
monsterram95's Avatar
monsterram95
if there was binding going on inside the gear box, then it probably be pretty hard to turn the steering wheel while parked or moving...does the steering wheel move fairly easily in either or both of these conditions?
Old Sep 30, 2010 | 05:35 AM
lennyb3us's Avatar
lennyb3us
yeah no problems with the steering really at all
Old Sep 30, 2010 | 11:28 AM
monsterram95
i know this sounds silly, but have you made sure all the joints (i.e ball joints, tie rod end joints) have been properly greased, and that the nuts on each of the joints have been torqued to spec?
Old Sep 30, 2010 | 11:33 AM
monsterram95
i would also look at the steering stabilizer, the track bar (plus the joint where it meets the frame, and the stud bolt on the opposite end), and sway bar (plus bushings)
