Steering Issue????????
Old Sep 29, 2010 | 02:21 PM
lennyb3us's Avatar
lennyb3us
Default Steering Issue????????
I have been chasing this noise for awhile. It started as a light rattle. I torqued down all the shock mount bolts and the rattle is gone. Now I have a sort of Pop noise when turning. I have checked the ball joints they don't seem to have any play. all the tie rod ends have been replaced as well as the shocks. Any ideas where I should look would be greatly appreciated.
Old Sep 29, 2010 | 02:40 PM
can you tell the general area that it is coming from?
Old Sep 29, 2010 | 02:44 PM
lennyb3us's Avatar
lennyb3us
I appears to be coming from the front d/s area, possibly under the pedals.
Old Sep 29, 2010 | 02:46 PM
open the hood, grab ahold of the steering shaft where the jointed shaft hits the steering column. Give it a shake. If it is sloppy, there is a fix for that. (and is generaly the cause of what you are describing. )
Old Sep 29, 2010 | 02:54 PM
lennyb3us's Avatar
lennyb3us
Are you talking about the shaft that comes out from the firewall and goes into the box?? There was minimal play there.
Old Sep 29, 2010 | 02:55 PM
What about the steering column itself? It isn't rotational play you are looking for here, it is just general slop in the bushing at the base of the column.
Old Sep 29, 2010 | 03:30 PM
lennyb3us's Avatar
lennyb3us
I'll check it out, would that be the rocksolid link I've seen on the forum for the steering fix?
Old Sep 29, 2010 | 03:32 PM
Yep, that would be the one.
Old Sep 29, 2010 | 05:26 PM
redheadhunter21's Avatar
redheadhunter21
Have you jacked up the front of the truck and tried to shake each tire, if it is any of the ball joints, the tie rod ends or either arms you should be able to hear it or notice the play
Old Sep 29, 2010 | 10:26 PM
monsterram95's Avatar
monsterram95
the control arm bushings could be worn, creating a little play in the arms themselves...if you had 4wd, then i would say there could be binding going on inside the front differential, but that's not the case here...also, examine the pitman arm and make sure that is torqued to the bottom of the gear box
