Can't figure this out, rear drums locking up
Old Feb 9, 2020 | 11:46 AM
  #21
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Rear ABS on these trucks was never really worth much.
Agreed I personally hate ABS. Now I can't do my famous 180 when I'm running from the local Sheriff for drinking to much fun juice
Old Feb 9, 2020 | 12:05 PM
  #22
Mr. Magoo's Avatar
Mr. Magoo
True but the valve can get stuck allowing full fluid to be put to the rear from my understanding.
to earlier query: took it back to guys that replaced rear brakes/drums. said maybe proportioning valve. have swapped that 2x, no change am going to try manual valve inline to back brakes like race cars have
very odd no one i talked to ever knew of this: "yeah, saw that before, it's___________.
took to a doge dealer & they said i need a new transmission. never go there again! gotta be something simple but goofy.
Old Feb 9, 2020 | 12:30 PM
  #23
MoparFanatic21
There are 4 things it could be. It's a simple setup.
Master Cylinder
ABS Valve
Proportioning Valve
Rear Brakes or Drums
Just because you replaced a part doesn't mean it's good. You are either getting to much pressure to the rear or brakes are bad. Seeing that the wheel locks up tells me ABS isn't working. Get that fixed and that should fix your problem.
Old Feb 9, 2020 | 02:36 PM
  #24
HeikIlm's Avatar
HeikIlm
What's the condition of the parking brake cables? I had cables that half worked; they would work as should, but when I released the parking brake, spring at the end of a cable couldn't pull the cable all the way into the drum, therefore leaving the parking brake lever partly applied and making the adjustment major PITA. Either they were dragging or they were too far, balance was off and they would lock really easy. Replaced both cables, quick adjustment and bam, zero problems after that.
Old Feb 10, 2020 | 07:19 AM
  #25
Mr. Magoo's Avatar
Mr. Magoo
Master Cylinder
ABS Valve
Proportioning Valve
exactly where is abs valve on 96 2500?
thx
Old Feb 10, 2020 | 08:21 AM
  #26
If it's RWAL, down at the base of the firewall, near the proportioning valve.
Old Feb 10, 2020 | 10:48 AM
  #27
MoparFanatic21
Yep mine just showed me the ABS and Brake lights today. I'll deal with it in the summer
