what gains to expect from headers?
Old Oct 1, 2010 | 01:35 AM
97vee10's Avatar
97vee10
Default what gains to expect from headers?
what kid of gains am i looking at from some headers on my 97 V10? is it worth it? im looking at some gibson GP304 headers from summit. and of course im going to go with aftermarket exhaust, magnaflow cats and mufflers.
Old Oct 1, 2010 | 09:21 AM
If you put on a nice, free flowing exhaust, you WILL notice a difference. As for exact numbers, that depends on what else you have done to the truck, and what condition everything else is in.
Old Oct 1, 2010 | 09:40 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Here is a pretty informative article on the subject, it doesn't pertain to dodge rams specifically, but it still a good read.http://www.superchevy.com/technical/...der/index.html
Old Oct 1, 2010 | 10:20 AM
Mowhawk's Avatar
Mowhawk
There was a similar article I read awhile back (cant find it now...) but it dealt with the 5.9 LA style. With just headers and no exhaust, shorties headers put out 7hp on the dyno past 2500rpm and long tubes put out 13hp past 2500rpm.
So theres is a difference, small as it may be but a difference. You'll notice a little more pep in the upper range of your power curve.
Old Oct 1, 2010 | 12:59 PM
zman17's Avatar
zman17
Either way, without other extensive mods, you"ll lose some low end.
Old Oct 1, 2010 | 02:13 PM
97vee10's Avatar
97vee10
so for towing, headers would not be a good idea?
Old Oct 1, 2010 | 02:34 PM
zman17's Avatar
zman17
Not headers alone.
Old Oct 1, 2010 | 03:17 PM
UnregisteredUser's Avatar
UnregisteredUser
It depends upon the headers. The Thorley Tri-Y (if they make 'em for the V-10) while expensive would probably do you well. I've had Tri-Y's on a couple of vehicles I built for low- to mid-range (towing and off-roading) and was quite pleased with them. They weren't the only modifications I made so I can't swear that all by themselves they'll be better than sex, but with other sensible modifications all intended to produce power in the same range they were great.
Edited to add: Yep, Doug Thorley makes 'em for your truck.
