One of the wires running into my tranny has broken. Is there an easy way to fix this or do i have to pull the whole trans away form the block and reconnect the wire? thanks for all the help
So one of the wires to the crank sensor is broke? Or a wire in the harness going to the trans is broke? WTF? One has nothing to do with the other. Replace the crank sensor or get a soldering iron and some shrink wrap or liquid electrical tape.
