Oxygen Sensor
Old Oct 1, 2010 | 02:07 PM
pjpriore's Avatar
pjpriore
Default Oxygen Sensor
Can i get my engine to ignore the fact that my oxygen sensor doesnt work so the check engine light will go off...from what people have told me the oxygen sensor just measures fumes that exit the truck and doesnt do much for the engine other than that?
Old Oct 1, 2010 | 02:15 PM
ferguson30's Avatar
ferguson30
Depends on how many sensors your truck has, and which one you are referring to, and why it is going off. The sensor(s) in front of the catalytic converter help to monitor the engine and tune performance based on what it sees. The ones behind the cat don't do anything but monitor that the cat is working. You can buy dummy sensors if you gut the cat. But sensors are just as cheap so you might as well just replace them unless you are doing something funny with your exhaust.
Old Oct 1, 2010 | 02:18 PM
pjpriore's Avatar
pjpriore
its the downstream sensor that doesnt work anymore
Old Oct 1, 2010 | 02:24 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Could we have some friggin more info about your truck and the way you have the exhaust system setup????????????
Old Oct 1, 2010 | 03:22 PM
UnregisteredUser's Avatar
UnregisteredUser
You'd be better off just plugging in a sensor.
Old Oct 1, 2010 | 04:05 PM
Jr. Mechanic's Avatar
Jr. Mechanic
I don't know what all the hype is about lately with people thinking it's beneficial to eliminate things like the oxygen sensors and cat. Removing the downstream sensor will not affect performance, but there's no benefit. Removing the upstream sensor will keep the PCM in open loop, completely hindering any ability to adjust the fuel mapping.
Eliminating the cat may give you a couple HP, but it's not noticeable. You may say your "butt dyno" says it is, but it's not. The only thing you're accomplishing by doing so on a stock to mildly stock engine is violating federal law, increasing the amount of pollution your truck produces, as well as making your truck less pleasant to drive behind.
Sorry to the OP since most of this doesn't really apply, it's just a rant due to the rash of O2 and cat threads lately.
Old Oct 1, 2010 | 09:33 PM
dhvaughan's Avatar
dhvaughan
that alone makes it worthwhile.
Old Oct 1, 2010 | 10:48 PM
drewactual's Avatar
drewactual
If'n you ever find yourself on the coast of north carolina, I'll buy you a beer. cheers!
