#5 misfire
Old Oct 23, 2010 | 06:55 PM
  #31
csobania82's Avatar
csobania82
i did read the damn can!!!! it says it can be added to the fuel tank, treats 8-25 gallons of gas... also it says can be added to oil crankcase...also says add to fuel line or vacuum line. says multi use. seafoam motor treatment thats why i'm askin for help so chill dude!!!!!
Old Oct 23, 2010 | 07:03 PM
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
You CHILL! Read my post again. Did I say to put the Seafoam in the gas or the oil?????? Or did I say to use Techron in the gas???????????
Old Oct 23, 2010 | 07:09 PM
  #33
csobania82's Avatar
csobania82
i didnt see any techron at the store i went to, and u said try seafoaming the intake, sounds like sprayin it or something. ive never use seafoam before so i wasnt sure. thats also why i was askin if there are different types of seafoam. the can said dump in fuel tank so figured that will work like techron i dont know. do u dump the seafoam the the throttle body then or what?... all i know is i keep spendin money and nothin works. makin me wanna sell it.
Old Oct 23, 2010 | 08:47 PM
  #34
drewactual's Avatar
drewactual
Vacuum line. Stand by for mucho smoke. that's what you wanna see though. if you use synthetic oil it will likely do you no good in the crankcase, they kinda do the same thing. (Detergents in syn oil and all).
I hope you whoop this thing!! Btw- the heater core hose isn't going to hurt anything staying on there, but it was just meant to isolate the issue as a possible grounding wire.
Old Oct 23, 2010 | 09:06 PM
  #35
csobania82's Avatar
csobania82
naw i use regular oil in this pig. yea i figured id just leave the heater hose on. is it normal for the iac valve to not change engine characteristics when unplugging it? seems like i wasted money on a new one even though the old one looked hammered. hell i even put a new map sensor. replaced damn near everything. seems to accelerate smoothly but has a bumpy idle. i also noticed today that when driving say 60-70mph if i let off the throttle all the way it'll like coast for a second then it'll kinda bog or slow down more than normal. say if it was a manual transmission then u down shift early and u listen to it rumble. does that make any sense? of course i have an automatic so.... i banged on the cat, didnt hear any kind of rattle or anything.
Old Oct 23, 2010 | 09:28 PM
  #36
drewactual's Avatar
drewactual
Yeah, that makes sense. Its down shifting and the equiv of engine braking.
I was leaning toward vacuum issues, but that doesn't fit either, exactly.
