transmission cooler
Old Oct 4, 2010 | 10:31 AM
yellowbeast's Avatar
yellowbeast
Question transmission cooler
so i just did some research and found out i have a transcooler rated for 3500 gwt my trailer is more than that about 4500 just trailer, but its better than nothing right? and also is there a thermostat for them? leaving on friday for the big trip and trying to get everything all set
Old Oct 4, 2010 | 07:42 PM
dhvaughan's Avatar
dhvaughan
anything is better than nothing, but bigger is better.
no thermostat, but some of them have a cold weather bypass built in.
smaller
http://www.bmracing.com/PRODUCTS/Aut...n-SuperCoolers
larger
http://www.bmracing.com/PRODUCTS/Universal-SuperCoolers
Old Oct 4, 2010 | 08:16 PM
UnregisteredUser's Avatar
UnregisteredUser
To add to the above list: scroll about 3/4 down this page to part number 10L. I was just out looking at the stock setup in my truck, and it looks like that 45,000 BTU/40,000 lb GVW cooler w/cold weather bypass will fit in the stock location with just a bit of bracket wizardry. That's the unit I'm going to install sometime before next summer.
Old Oct 4, 2010 | 08:46 PM
atlrus's Avatar
atlrus
Your tow rating is about 8,000 lbs. You can see specifics here (since I dont know your model): http://www.trailerlife.com/images/do...owingguide.pdf
The best solution is to get a bottle of Lucas transmission additive and pour it in. It will lower your tranny temp by at leats 10 degrees when towing.
If your truck is still overheating towing the 4500lbs trailer then you have a problem. Is it a travel trailer by the way? If so, you may want to consider getting AAA with the camping opiton, this way they will take care of your truck and TT.
I'm very **** myself when getting ready for a trip, especially if familly is coming along, but there is so much you can do Anyway, you are well within your towing capacity and shouldn't worry about that. I would look into adding more tranny cooling only if towing 7-8000lbs on a long trip.
Old Oct 4, 2010 | 09:07 PM
dhvaughan's Avatar
dhvaughan
in montec's transmission threads he says about a thousand times not to use that ****. there's only one additive he recommends and that's smart blend.
smart blend - yes
https://dodgeforum.com/forum/2nd-gen...nd-montec.html
lucas - no
https://dodgeforum.com/forum/2nd-gen...-additive.html
Old Oct 4, 2010 | 09:38 PM
atlrus's Avatar
atlrus
Well, that's good for him. I have used Lucas in a few different vehicles and I have seen with my own eyes the temp drops by more than 10 degrees when towing a 7200lbs travel trailer, after adding a bottle of Lucas to a "clean" ATF. I also have 111,000 miles on my Escalade and have always used Lucas in it, my transmission runs like the day it was assembled (and I tow often with it).
I am not sure if Lucas helps with slipping trannies, since I've never had one that slips, but I know it will lower your temp and so far I've never rebuilt a transmission.
