Help!?!?!
Old Oct 4, 2010 | 12:28 PM
liquidkool's Avatar
liquidkool
Default Help!?!?!
97 5.9 liter burning alot of oil- i'll top it off, and it will be 3 qts low after roughly 150 miles. truck has 153,000 has no OD and drive mostly on highways. Please help, what should i replace?(valve guide seals) it doesn't drip or leave any puddles under the truck, doesnt smoke when in park?!
Old Oct 4, 2010 | 12:31 PM
dodgeboy1979's Avatar
dodgeboy1979
Check down your throttle body, It could be your plenum gasket has blown.
Old Oct 4, 2010 | 12:35 PM
liquidkool's Avatar
liquidkool
going to check now thanks!!
Old Oct 4, 2010 | 01:24 PM
liquidkool's Avatar
liquidkool
removed throttle body and im guessing that there shouldnt be oil in there correct? does this mean that the plenum gasket is blown?
Old Oct 4, 2010 | 01:34 PM
UnregisteredUser's Avatar
UnregisteredUser
Rather than assume that oil in the belly pan is a blown plenum gasket, try running the test outlined in the TSB. Also check/replace your PCV valve.
Old Oct 4, 2010 | 07:35 PM
dhvaughan's Avatar
dhvaughan
its blown. hughes plate is your answer.
Old Oct 5, 2010 | 02:59 PM
liquidkool's Avatar
liquidkool
yea it was blown, took it all apart, replaced all gaskets just finshed putting it all back together but now it wont start. motor spins but wont fire, checked the fuel line at the rail and its getting fuel............what did i do now???
Old Oct 5, 2010 | 03:39 PM
liquidkool's Avatar
liquidkool
anyone have any clue what to do
Old Oct 5, 2010 | 03:57 PM
UnregisteredUser
You find the wires you either forgot to reconnect or pinched while putting the manifold back on, probably. Those are the most common errors, anyway.
Old Oct 5, 2010 | 04:22 PM
liquidkool's Avatar
liquidkool
its all as it was ...the harness was on top of the valve covers so i know nothing was pinched...wtf i need it to start i need my truck for work tomorrow
