leaky trans dipstick
Old Oct 4, 2010 | 10:11 PM
bobracing32's Avatar
bobracing32
Default leaky trans dipstick
I just installed a new trans and with the motor running i filled up the trans to the full point. Its been sitting for 2 hours and its leaking like crazy frome the dipstick housing. The o ring is good im just not sure why this is doing it please help.
Old Oct 4, 2010 | 10:33 PM
J415's Avatar
J415
How many quarts did you use? It should be right around 10.
Old Oct 4, 2010 | 10:39 PM
bobracing32
to be honest i have no idea pumped it straight out of a 5 ga bucket. id assume around ten.
Old Oct 5, 2010 | 10:22 AM
Recheck your fluid level with the engine running, warmed up, trans in neutral. Make sure you run it thru all the gears once, to make sure everything is 'full'..... See what the level looks like.
