need help please give some ideas loss of power
Old Oct 4, 2010 | 11:40 PM
cometdave95's Avatar
cometdave95
Exclamation need help please give some ideas loss of power
i have 1995 dodge ram 1500 ext. cab short bed. i put shorty headers with dual 2.5 inch pipes with 40 series flowmaster exhaust, and i put a short ram intake. on it with all this my truck runs really slugish what can be recommended what do i do to fix this problem it doesnt have a catalyc converter. but the o2 sensor is still mounted to the exhaust pipe a hole was made to the pipe with a fitting for the O2 sensor
Old Oct 5, 2010 | 07:51 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Others will chime in, and if you do a search here on DF, you will find a lot of info about the subject, but, it seems to me that you have the exhaust opened up too much.
Old Oct 5, 2010 | 10:16 AM
Which intake did you put on, specifically? Link?
Old Oct 5, 2010 | 01:35 PM
jasonw's Avatar
jasonw
Site Moderator
I echo HeyYou's thoughts, what intake did you install?
Dual 2.5" pipes is quite large for a mostly stock truck. Dual 2.25" is pretty much as large as you should go even for a mildy modified truck, or a single 3". You may have to spend some more money on upgrades to catch the engine up to that large of an exhaust.
Old Oct 5, 2010 | 04:12 PM
zman17's Avatar
zman17
Not to mention the blown plenum and deathflash.
Old Oct 6, 2010 | 11:03 PM
cometdave95
make sense but what type of intake manifold should i buy and how difficult is it do i just want my truck to run fine now its slow and i can t even burn out at all its frustrating does it matter if it fuel injected just want to know what type to buy so i can look into it and buy it what will i need .
Old Oct 6, 2010 | 11:04 PM
cometdave95
i i installed just a short ram intake no manifold yet
Old Oct 6, 2010 | 11:10 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Its a 95, so it shouldn't be able to have the deathflash since its OBDI, right?
Instead of doing the intake, you might look at a plenum, MOPAR performance PCM, Harland Sharp 1.7 roller rockers, 50 or 52mm throttle body, kegger mod, throw some 4.10 gears back there....I'm sure there's other stuff I'm missing.
If you did all that, it might make things interesting, thats for sure.
Old Oct 6, 2010 | 11:39 PM
CPTAFW163's Avatar
CPTAFW163
with NO CAT your downstream O2 sensor is picking up rich. SO it is compensating by not putting in as much fuel. Take it off completely (O2 sensor) and it will default to rich to prevent detonation.
You need an O2 simulator from www.thefastman.com
THe mods you did will not do much for power. You need to spend abo0ut 2K to see something (1.7s, plenum fix, and a SCT).
And I don;t think anyone knows what the hell a "Short Ram Intake" is.
Old Oct 7, 2010 | 12:56 AM
dodge dude94
^I'm thinking the short ram is an intake with a large diameter, short tube....supposedly gives a ram air effect.
I may be wrong though.
