cleaning intake manifold
Old Oct 5, 2010 | 05:29 PM
csobania82's Avatar
csobania82
Lightbulb cleaning intake manifold
whats the best way to clean the old gasket and gunk off the intake manifold and engine block? seems really cooked on there. can i use a wire brush? or will that ruin the surface? thanks!!
Old Oct 5, 2010 | 05:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Putty knife and razor blades in a holder. Then use a sanding block with fine sandpaper. Clean both surfaces with denatured alcohol,then procede with installation.
Old Oct 5, 2010 | 06:16 PM
seabass202's Avatar
seabass202
yes, what zman said, I just did this. I used a less than new razor blade to avoid gouging. I also had a plastic cup to tap the gunk off of the razor so it wouldn't get into the lifter valley. took some time but cleaned up real nice. everything sealed up great.
Old Oct 5, 2010 | 06:43 PM
zman17's Avatar
zman17
Also,stuff rags or paper towels in all the ports. And use a vacuum instead of compressed air to clean up debris.
Old Oct 5, 2010 | 08:12 PM
atlrus's Avatar
atlrus
You can stuff the ports with shop towels and use either TB cleaner or brake parts cleaner. Both work magic with gunk and evapotate quite quickly - all the gunk will be left within the towels.
I am sure it will also unglue the old gasket parts.
Old Oct 5, 2010 | 08:16 PM
dhvaughan's Avatar
dhvaughan
scotch-brite pad works good too.
Old Oct 5, 2010 | 09:13 PM
littletunny's Avatar
littletunny
This looks like it works good if you got the equipment:
http://www.youtube.com/watch?v=2lM7IgqMAiA
Old Oct 5, 2010 | 09:24 PM
duneslider's Avatar
duneslider
Anyone know where to get those sweet little 3m bristle pads? I have a die grinder and would much prefer that to scraping away.
