Front End Binding and Other Noises
Old Oct 6, 2010 | 09:08 PM
Cliffton05's Avatar
Cliffton05
Default Front End Binding and Other Noises
I have a 96 Dodge Ram 1500 4X4. 2 years ago I went off the road in a pretty nasty snowstorm. Really had to romp on it to get out of the ditch. After that my front axle started binding (feels like it's trying to jump out from under the truck) while in 4wd. I haven't ever put it back into 4wd since then. What could be causing this.
Also recently it has started to whine driving down the road at all speeds. when you slow down and hit around 10mph it just suddenly stops making the noise. I replaced the wheel bearings around a year and a half ago. any help would be great
Old Oct 9, 2010 | 02:32 PM
Cliffton05's Avatar
Cliffton05
Well I did look at the front end and I have a bad U-Joint on my passenger side front axle. But I believe the binding is caused by something else. Any Ideas?
Old Oct 9, 2010 | 03:02 PM
If it feels like it is binding on dry pavement.... that is normal.
Jack it up, and inspect everything. Turn the moving parts, be sure that everything 'feels' good. If not... replace it.
Old Oct 10, 2010 | 12:25 PM
Cliffton05's Avatar
Cliffton05
No it was while in the snow. The front end acts like it is trying to jump out of the truck. I haven't had it 4wd since that day 2 years ago.
Old Oct 10, 2010 | 12:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It's the ujoint(s)! Did you fix it?
Old Oct 12, 2010 | 11:40 AM
Cliffton05's Avatar
Cliffton05
I have not fixed the u-joint yet, I haven't had the time, nor the tools or resources right at this very moment. Time is hard to come by in my life as i work a lot and have very little time away from work.
Old Oct 12, 2010 | 12:16 PM
zman17's Avatar
zman17
I wouldn't wait too long. If the seal goes bad, you'll have a bigger problem.
Old Oct 13, 2010 | 07:45 PM
Cliffton05's Avatar
Cliffton05
I will get it fixed as quickly as I can. as for the binding, it was happening while in the snow not on dry pavement. Should I brave putting it in 4wd and seeing what happens??? I know it was not caused by the u-joint as it was good 2 years ago when it started binding up. the U-joint going out is a rather new issue. thanks
Old Oct 14, 2010 | 12:43 AM
matty675's Avatar
matty675
like he said its normal to bind on dry pavement, so doing that wont help you. you know for a fact the joint was good? theyre super easy to replace, however it does require taking the shaft out which is a bit involved. but easy with the right tools
Old Oct 14, 2010 | 08:16 AM
Cliffton05's Avatar
Cliffton05
I do know for a fact the joint was good. That was the first thing I checked back in 2008 when this all happened. Although I have one that is bad now. I have tried searching for and EDU on here but haven't seemed to find one, (passenger side).
As for finding out if it still binds, what are my options? go back out in the snow and see if it still binds? Since it will bind up on dry pavement that wont help in checking it out. Jack up all 4 wheels and see if it binds up that way?????
