running a little hot at 230
Old Oct 7, 2010 | 11:27 AM
Joey Buentello's Avatar
Joey Buentello
Default running a little hot at 230
i plumbed a t into my heater core line to run a t-stat sensor for my e-fans would this act as a restriction and keep my truck from running cool?
Old Oct 7, 2010 | 11:32 AM
zman17's Avatar
zman17
Retired Moderator - RIP
No, but which one did you put it in? And I don't think that's the best place to put it as far as the fan is concerned.
Old Oct 7, 2010 | 03:20 PM
Joey Buentello
i put the T in the heater core line going fron the intake to the heater core. I was thinking about removing the T totally and just relying onthe toggle switch, leaving it on all the time. also could an o2 sensor make my truck run hot?
Old Oct 7, 2010 | 03:31 PM
zman17's Avatar
zman17
Where you put the T is in the coolest line possible. I don't have an E fan, but I thought most setups, stick the thing in the fins of the radiator
Old Oct 7, 2010 | 03:37 PM
UnregisteredUser's Avatar
UnregisteredUser
Only if it's failed in such a way that the PCM is dialing the mixture to a severely lean condition. You'd probably notice it, as it'd ping like a box of BB's dumped into a bathtub.
Old Oct 7, 2010 | 05:29 PM
Joey Buentello
it kinda hesitates off the line like its starving for fuel. i thought the heater hose intake line was a good place. also it idles at 200.
Old Oct 7, 2010 | 05:35 PM
zman17's Avatar
zman17
That is the return line, not the supply. It will be cooler and not be accurate. BTW, Have we talked about 35" tires with 3:55 gears and the plenum? LOL
Old Oct 7, 2010 | 07:57 PM
Joey Buentello
aps plenum kit installed - which is the heater hose intake line? what would cause my truck to run this hot?
Old Oct 8, 2010 | 05:59 PM
Joey Buentello
Default Hemifever's SCT Tunes
Whats up with his custom tunes? Interested.
Old Oct 8, 2010 | 07:16 PM
dodgeman2289's Avatar
dodgeman2289
hes got a sct tuner im looking into buying
